Blocking off an unused 13 amp double socket
13 Oct 2016
I want to remove a double socket and fit a blank plate in its place. Since we may decide that we want to replace the socket sometime in the future, what is the best way to make the cables safe in the interim period?
Any point in fitting a blanking plate as same thickness and size?
To answer
Fit double wago connectors
The Ls must be connected together,
the Ns must be connected together and
the Es must be connected together.
Any suitable connector may be used. The Es can go in the back box E terminal.
You should have two lives. Two neutrals as its a ring.
Could be a spur socket with just 3 wires I guess.
To answer your question, yes....
I would just buy some double wago and use one hole in each
Yes. The socket is never used but for some reason intrigues a very young visitor's prying hands.
You might want to consider these as an alternative. £1 for a pack of 5 from The Range... Other suppliers are available ;)
Features​
  • Prevent children from playing with plugs
  • Includes five covers
  • Great for any home
Information​
A good way to prevent young children from playing with plug sockets, this Pack of Five Safety Socket Covers protect from fingers getting caught and causing injury. With five included in the packet, these covers are perfect for covering up prominent sockets around your home
Since we may decide that we want to replace the socket sometime in the future.
They would be an easier way to bring the socket back into use too.
if you are covering with a blanking plate then its still accessable then you could just use some 30A connector strips - available from toolstation and screwfix for under £1
Personally
the plug inserts maybe ok if covering up the socket so children CANNOT reach - but a lot of research says these things are dangererous , i removed all mine and stopped using
google them and see reports from various sources including which
You might want to consider these as an alternative. they would be an easier way of bringing the socket back in to use in the future. £1 for a pack of 5 from The Range... Other suppliers are available ;)
Information​
I think not.....
Interesting, I wonder why they are still so readily available and selling then has not been banned in the UK :unsure:
I wonders how long it would be before someone posted this
F*** no. All those things do is turn sockets into a game, and provide an easy way for kids to defeat the very good built in protection gate that seals off the live terminal
Simply turn that thing upside down and push it into the earth pin hole to open up the live, then let a child stick a finger/small metallic object in
Anyone considering use of those things needs a reality check
No one has championed the cause hard enough(/no deaths have been conclusively linked to them yet?)
And people are thick/don't know how sockets work
I have repeatedly demonstrated to a local churchs officials how easily these ****ing things cause problems by partially inserting the earth pin upside down then giving it a thump which typically pushes it right in and snaps off. Each time they go round and dispose of them but within a few months they get replaced.
Get longer plate fixing screws. Affix blanking plate atop the existing double socket. Do one screw first, then the second. No need to disturb existing wiring that way.
May not be suitable solution for a double switched socket though.
Better would be to teach youngun that there's nothing worth investigating there. Not that they should come to much harm unless wielding a heavy metal toy and breaking the socket (or blank plate for that matter).
