Cable Tracker with Tone Generator
No what you linked to does NOT do the same.
Have a merry Christmas Day Mottie. :)
Merry Christmas to you too, mattylad. ;) :ROFLMAO:
I have one of those too, they check continuity, that there are no crossed connections, or shorts, work quite well, but you need to make sure the light sequence is the same, at both ends.
Hah hah yes. we had a job some 25+ years back where a rack had been removed and the cables reterminated in another rack. No idea what skills the guy had but he had managed to terminate them incorrectly - the lights flashed in sequence but out of step with each other. The kit we patched to it simply didn't work and of course patching back so the 2 halves of the tester were side by side the flip was cancelled out. It took some head scratching until I used a tone tracer to prove a cable one pair at a time.
Lights out of sequence (e.g. 1-2-3-4-5-6-7-8 on one side and 1-2-4-3-5-6-7-8 on the other) means swapped wires.
Two or more lights on at the same time means two wires shorted together, missing light is wire open (not at all).
Some of mine, ran for miles down river banks, level sensing, alarms, and telemetry. I devised a pair of army surplus telephones to help with the job.
I once wasted a lot of time when I didn't spot that it was showing 12345678 at one end and 87654321 at the other.
When they are a great didstance apart and it ran
5-6-7-8-1-2-3-4 on the other
how many would instantly question it?
On the unit I have there are 4 leds marked
1&2-3&6-4&5-7&8
Flashing green = good, red = flipped, out of sequence = out of sequence, dark = one or both wires missing
Years ago I made a manual version to test leads, basically a box divided down the middle as send and receive sides with 10 LEDs side by side and a rotary switch to light each in turn on one half. I fitted pretty much every type of socket up to 9pin + enclosure used in AV work at the time except 8P8C and speakon but soon made a few adaptor cables.
That's fairly obvious because there is a pause when it wraps around from 8 to 1.
But is the gap for 9 really that obvious when it happens?
The only reason I ask the question is as always the experience.
