External garage electricity wrongly connected to neighbours supply
Maybe I'm being dim, but could you perhaps explain that statement?
Other than in TN-C-S installations, there is not uncommonly a significant N-E potential difference (due to VD in the supply neutral) - and, indeed, even with TN-C-S there is not uncommonly a significant PD between the CNE/PEN (hence N & E within the installation) and 'true earth' (for the same reason). However, in no case does that result in any 'potential for tripping' of an RCD.
Of course it does.
Of course it does.
You may regard it as a matter of "of course" but, as I wrote, even if it's because of my being dim, I'd be grateful if you could explain why you believe (if I understand you correctly) that a significant N-E potential difference may result in an increased possibility of RCD tripping. Thanks.
My guess as to what is meant.... With a potential between N & E, even when the MCB is off, shorting N to E, can cause the RCD to trip.
If there are any active loads on any circuits in the installation, an N-E fault (on a final circuit, even if its SP MCB is 'off) will result in an RCD trip even if there is (or was, prior to the fault) no potential difference between N & E, won't it?
That being the case, I therefore can't really even "guess" what situation/mechanism Sunray was thinking of.
