No hot water in electric shower
30 Mar 2015
I’ve got a triton cara 8.5 kw shower that’s stopped providing hot water. It has a power supply and cables are well connected.
I notice that there is no continuity between the screws I have circled in yellow. Is this likely to be the issue?
Is it providing cold water. If not you need to rectify that before replacing the cut out
Yes cold water regardless of where the shower dial is. If it’s turned to hot, the pressured reduces ( like it did when. It worked) but the water is still cold. Does it still point to thermal cut out?
