You're starting to get mixed up
The position of L1 and S1 are fixed in the Surewire by the internal electrics in the white strip between the terminals with
Line (Live) going to the switch and
Neutral to the light and a
Switched Linebetween (I hope I have the numerical designations correct in this pic as I cant read any of the markings but have followed the line sketch)
This
is what you are indicating but you will need to add the link in the Surewire which I've shown in purple (just to make it obvious).
Ultimately you will need to connect to L from S1, E from S1 or L1 & N from L1 which your suggestion achieves.
These are electrically the same and any of the 4 versions are acceptable, only 2 require the link wire:
