A lot of bathroom cabinets come with a 2 pin shaver socket.
Do you have a make/model for the socket?It's a new socket
Well, in practice, not much difference (unfortunately). so they often gets used interchangeably, which can be a bad thing sometimes because of tolerances it can put a undue strain on them - and that`s if they are made within their own spec which I suspect some are not quite either.I've never known a europlug (4mm pin * 21.5 to 22.6mm width) not correctly fit in a UK shaver socket made to multiple standards, or for that matter not known them not work in a BS372 socket (although in theory they shouldn't) but abroad there is often no provision for a BS4573 (5.1mm pin * 21.8mm width) where we end-up usingView attachment 407427View attachment 407428
My parents have (or had, I don't know if they still have it) an old adapter with 13A plug pins, a 5A 3 pin socket and two 2-pin sockets, presumablly to BS372. We found Europlugs did not work reliably in said adapter, they would work at first, but over time had a tendancy to either fall out, or loose contact.not known them not work in a BS372 socket (although in theory they shouldn't)
I still have and fairly regularly use a number of similar adapters; working with a selection of different AmDram groups one encounters all sorts of variations of historic standards and fashions, additionally working with Public Address systems and persons of all ages and nationalities I've regularly found I have to come up with solutions.not known them not work in a BS372 socket (although in theory they shouldn't)
can you accurately measure the centre to centre spacing of the holes.This is the socket, it's inside a bathroom cabinet.
I am hoping that I can use it to charge an oral-B toothbrush with it.
My main concern is if the pins are smaller then it may fall out as it is facing downwards.
I'll get one off of Ebay and try it thanks.
Maybe this one.
My interpretation:running the numbers.
A Europlug has pins of 4mm diameter, spaced 18.6mm between centers at the base and 17.5mm between centers at the tips. That gives, at the tip an outer width of 21.5mm and an inner width of 13.5mm.
A UK shaver plug/BS372 2 pin 5A plug has 16.7mm between centers, and a pin diameter of 5.1mm. That gives an outer width of 21.8mm and an inner width of 11.6mm,
So "theoretically" a 0.3mm gap, but the contacts on the socket are probablly designed to Squeeze the pins a bit. Also those are measurements at the tip, closer to the base the contacts will be futher apart. On the other hand, the contacts in the socket may not be mounted entirely rigidly.
