- Joined
- 27 Jan 2008
- Messages
- 29,355
- Reaction score
- 3,608
- Location
- Country
TRVs obviously existed, and were very widely used, long long before anyone had heard of modulating boilers.
Condensing boilers were developed in the Netherlands in the late 1970s.
I had a non condensing in my house 1979 approx, but my sister around 1990 had a condensing boiler, and her house was the first I saw with one direction TRV heads, later versions were bidirectional.Modulating central heating boilers, which adjust their output to meet demand rather than turning on and off, became mainstream in the UK following the mandatory implementation of condensing boilers on April 1, 2005.
The first I saw was Honeywell EvoHome, originated from the "Hometronic" system launched by Honeywell in 1996,Where are these thermostats located? What aspect of their 'flavour' removes the need for wall thermostat(s)?
today the Drayton Wiser allows I think around 9 thermostats be they TRV or wall mounted to be linked to the hub, some makes the TRV links to the wall thermostat/hub, others use an independent hub, I find only need one bedroom with a linked TRV head, as once boiler is fired by one, other TRV heads will work anyway. Personally I like having a wall thermostat, mounted on an internal wall, I know I can set the temperature higher or lower with voice commands, but I just like the idea of a wall mounted unit, even if strictly not required.There is one make where the lock shield is part of the TRV, it was it seems designed to make the setting of them up easier. Think the green bit shown hereWhat do you mean by that?
As to what is 'new-fangled' it seems from the 90s to present day the TRV has been evolving, year by year, we had wax, and bellows, with the mechanical types, and uni-directional to start with, had to be fitted on the inlet side, no option to fit on return side, then bi-directional came out, the law required zones, and it seems people read the law different to each other, some LABC considered the TRV created zones, but many plumbers seemed to think it needed time as well as temperature control to be considered as a zone.They would presumably be 'new-fangled' ones!
So the whole way the modulating boiler works requires gradual turning of zones on/off, or many zones, the EPH I know do a thermostat which can be set to master and many slaves, but most thermostats even when they have OpenTherm, say it should not be used with multi-zone versions of the thermostat, EPH seems to be the odd one out. Wiser do a three channel hub, and Hive have some way to link thermostats, I think the universal base
is asking for problems where the same base can take a volt free and non volt free hub/thermostat/programmer, and it is a pain to test, as once hub is fitted you can't access terminals.But today with a modulating boiler, one has little option, if you want it to modulate correctly and gain the latent heat but to control all with the TRV heads, which, if one feels the new laws require time settings for the zones, the only option is to use electronic heads.
I had a problem in parents house, the thermostat fitted,
With modern central heating, we need analogue controls. OK turning on/off twice a day, but not 10 times a day, it seems the law has resulted in installations which don't suit the boilers being used. Instead of it making the boiler more efficent, it has made them in many cases less efficent.
I know my children used their bedrooms to do homework in, and when children left home, those rooms became an office, or a craft room, so the whole idea of splitting the heating upper floor and lower floor is flawed. My dinning room is not used at the moment, so set to 12°C actually sitting at 13°C, but without electronic heads on my TRV I could not really do this.
