Willis Heating System
28 Jan 2011
Buckinghamshire
The following comes from another current thread, which has somewhat 'drifted'. In a subsequent post to this one (please be patient :-) ), I'll attempt to move this discussion forwards!! ...
I think I must be dim, because I've always struggled to understand how the Willis system (as depicted in your diagram) can possibly work.
I cannot see why heated water from the Willis heater should travel downwards into the cylinder, which contains colder water. It will rise to the top of the column of water in the expansion/vent pipe, but I don't see why it should move downwards - and, since the connection to the taps comes off the expansion pipe below the connection to Willis heater, I would expect it to draw water (for the taps) from the colder water at the top of the cylinder.
What am I missing?
I assume it starts a flow, and the gate valve regulates the flow, but can't find the Willis website. I liked the idea, but I am not sure how it will work with varying output from the immersion heater?
The heated water will rise up through the heater via thermosyphon, as it does it draws cooler water from the bottom of the cylinder, heating the cylinder from the top down.
As I said, with a Willis system simply as shown in the diagram you posted, I cannot understand how heated water would/could ever get into the cylinder. Nor can I see how any valves could alter that. I find it hard to believe that anything other than a pump could force heated water(hence lower density) to travel downwards into/through cooler water, despite gravity and Mr Archimedes.
Maybe the system is significantly more complicated (perhaps including a pump) than your diagram (and most other diagrams one sees) suggests?
I'm still pretty lost! ....
When all taps are closed, a small amount of water heated by the Willis heater will rise up into the expansion pipe, with the displaced cooler water moving downwards into the cylinder and/or the feed from the Willis heater. Since no water is being drawn, no water will be drawn from the bottom of the cylinder. So long as the taps remain closed, I cannot see why water at the top of the cylinder should get significantly heated - which would mean that there would be no significant heating of water in the cylinder whilst the taps remain closed.
When tap(s) are opened, water flowing to them will be a mixture of that from the top of the cylinder (which I would expect to be pretty cold, if taps had previously been closed) and from the Willis heater, the proportions via those two routes being determined by the relative resistances to flow in the two routes. What comes out of the taps would therefore seemingly be a mixture of heated water in the Willis heater (until it runs out) and of the (I would think cooler) water in the cylinder.
So, if it works (which I assume it must do), I must still be missing something.
It seems no pumps. I can see how therm-syphon will move the water, what I can't see is how there as any control as to how much water is heated.
The heated water doesn't go up the expansion pipe (ok the level might rise a bit) the cool water comes from the cylinder not the cold water feed tank, there will be no flow from the cold tank unless a tap is opened. thermosyphon is surprisingly effective, and the water will have no problems circulating around the cylinder. It has been used for cooling stationary engines for decades.
I'mnot sure that I can! "Move the water" from where to where? With all taps closed, I can't see why heated water should move anywhere, other than into the expansion pipe - remembering that water will rise through cooler (more dense) water and fall through warmer (less dense) water.
I presume that more-or-less all of the water in the Willis heater (however much that is) will get heated to the temp dictated by it's thermostat (I presume it must have one?). When a tap is opened, it will draw water from that in the heater (diluted by cooler water from the cylinder). That sounds to me to be similar to (but a bit 'worse than', because of the dilution) an 'instant hot water' unit with a small (1-5 litre under-sink reservoir) - in which case, as soon as all the heated water from the small supply (in reservoir or Willis heater) has been drawn, one will just be left with 'real-time' heating, which would need to be many kW to achieve a reasonable temp and flow rate.
I continue to assume that, IF the system works reasonably (are we sure it does?) I must still be missing something fairly fundamental!
I'm not talking about additional water moving into the expansion pipe. Rather, I'm talking about standard convection, with warmer (less dense) water rising through cooler (more dense) water, thereby displacing the cooler water which hence ends up below the warmer water - but with still roughly the same amount of water in the pipe (other than, as you say, a slight expansion).
Why? ... particularly given that (as I've also said) ...
I may need some educating here, since I was under the impression that a 'thermosyphon' was all about convection. As for it "having no problem circulating [water] around the cylinder", I agree that convection would have no problem in doing that IF some heated water were introduced into the cylinder - but my problem is in understanding how heated water from the Willis heater gets into the cylinder (seemingly contrary to the standard mechanism of convection)
Is the system not just similar to a gravity fed hot water cylinder from a (solid fuel) back boiler?
That is - it just works because because that's what happens.
OK. I don't think I have get moved appreciably on for my position in not really understanding (for the reasons I have outlined) how/why the Willis system can possibly 'work' (in the sense of heating the water in the main cylinder).
Mr Google seems to know surprisingly little about the Willis system. Attempts to do searches result mainly in hits relating to 'heating businesses' all over the place run by various instances of "Mr Willis"!
A combination of that and the theoretical arguments I've presented therefore leave me wondering whether this concept is not really just a variant of the concept of the "under-sink gizmo", which provides a relatively very small amount of stored hot water, making the main HW cylinder pretty irrelevant, with hot water reduced to either a trickle or a low temp once the small amount of stored hot water has been used up?
Not in terms of what I currently understand - as I've been saying, I don't yet see how it can result in much more stored hot water than the (small) amount contained in the 'Willis heater' itself - as I've said, like the 'under-sink' things.
To my mind, to function like a "gravity fed hot water cylinder", the hot water coming from the Willis heater would have to be connected to the main cylinder lower down (ideally the bottom), not above the top of it!
Thank you for moving,
I don't think so, remembering back to the side boiler in the Aga, it seemed to mix up the water, today we have a hot coil
so water does not mix anyway, but the Willis both electric and hot coil versions, the Heating is done in the external heat exchanger or immersion heater
and it puts water at a useable temperature into the top of the cylinder first, and as time goes by, the stratification layer goes further down the cylinder.
I know it works, but not sure how it works. I can find loads of pictures 1771610386536.pngshowing stratification and saying how to avoid it, but what we are looking at is how to control it. I think there has to be a stop tap
to control the speed the water transfers at, which is missing from diagrams I am finding. I have hunted and hunted for the Willis website, but it seems to have vanished.
Found on an Irish plumbing forum where there are a couple of threads about this, though nothing recent (2022)
"Because its external and connected to the top and bottom of the tank it sets up a very low powered thermal syphon so it pushes hot water out the top while sucking cold(er) water in from the bottom. Provided the water coming in at the bottom will keep the thermostat below the level its set at it will keep heating the water. It should work no matter what the height of the element in the Willis is in relation to the tank but the lower it is the better the thermosyphon will work so basically mount it a low as possible."
In essence It's operating in its own closed loop, so it will circulate and I suppose a bit like a ring main with a socket or a spur (acting as the hot water draw off point) the spur would draw current from both sides but in this case (water) more from the one with least resistance. Note that it is fitted "upside down" to ensure the element is completely covered and recommended to fit as low as possible to the feed/cylinder bottom & if possible 50/60cm above the draw off point at the cylinder top. Curved bends instead of right angles and full bore valves give best flow. Can be used in both vented/unvented systems with relevant safety pressure regulation
Haven't got one but considering it when I have my defunct combi replaced and re-install an immersion tank so I can have a bath for a change.
Seems perfectly obvious to me, it would work, and work well....
The element in the small Willis tank, heats the water in the small tank. Heated water rises, and flows into the top, of the main tank/cylinder, whilst at the same time drawing cold water in the small tank, from the larger one. The hot, will stay at the top, cold at the bottom.
The interface level, between hot at the cold, will gradually work its way down the cylinder, which means thermostats of various lengths, or sensor at various heights, could be used to preset an amount of hot water you needed, to then switch the element off.
It might be 'perfectly obvious' to you - but I nevertheless still need someone to explain to me why/how it 'works' ('well' or otherwise), despite what currently seems to me to be an 'obvious' conflict with the Laws of Physics.
The element in the small Willis tank, heats the water in the small tank. Heated water rises, ....
Indeed.
.... and flows into the top, of the main tank/cylinder, ...
As I've asked before, "why?". The heated water has a lower density than the colder water in the main cylinder - so, in a world with gravity (and Mr Archimedes, hence 'convection') why on earth should that lighter, heated, water move downwards ('against' gravity) into the main cylinder?
.... The interface level, between hot at the cold, will gradually work its way down the cylinder ...
As above, I cannot see why any hot water should defy gravity and move downwards into the main cylinder (i.e. 'convection').
It rises in the small tank, if it rises in the small tank, it has to go somewhere, that somewhere is to exit to the large tank, whilst drawing cold in behind it. It is not defying physics at all. Imagine, sort of, how two tanks, open to atmosphere, joined by a pipe at their bases, might work, in levelling up the fluid? This is similar, except it uses thermo-syphonic action - the less dense warmer water, rises to the upper of both tanks, because they are joined by a pipe at the top.
It rises in the small tank, if it rises in the small tank, it has to go somewhere, that somewhere is to exit to the large tank ...
No. Convection does not require any water (or whatever) to "go somewhere". In a standard bottom-heated (or 'low-heated') DHW cylinder, convection is happening all the time, with warmer water rising and cooler water falling within the essentially unchanging volume of the cylinder; no water "goes anywhere". Similar for convection within a room containing an essentially unchanging volume of air.
... whilst drawing cold in behind it. It is not defying physics at all. Imagine, sort of, how two tanks, open to atmosphere, joined by a pipe at their bases, might work, in levelling up the fluid?
The levels would obviously remain the same in both tanks. However, no water will move downwards (into or within either tank) unless it is colder than the water below it in that tank.
As I keep saying, in the main cylinder, there should be no 'less denser warmer water) lower down that could/mould 'move up'
I might have added ...
... I can see how the Willis system would work if the feed from the Willis heater fed into some point below the top of the main cylinder - BUT I can't see that that would be essentially any different from (or superior to) having an immersion at the same point (as the 'connection') in the main cylinder.
Wrong! The water moves, as does air.
You just contradicted yourself in one post there. The water moves, that is what a convection current is/does. Put your hand over a hot radiator, and there will be a warm, rising, flow of air above it.
Capture the hot air, in a balloon, and the balloon will rise.
Is your complaint/issue with the system that the heat exchanger is above the tank?
Does this lead you to believe that the water in the hx would just heat up and stay there, and the tank wouldn't warm at all?
I remember a thread about this a while back and the issue was a bit challenging , to see the issues and make a decision seemed on a parr with the voltage optimisation/snake oil debate - my conclusion with the voltage optomise thing was that in an extremely small set of circumstances it could mae a difference and more than pay for itself yet in an (again) small set of circumstances it could make a difference and not pay for itself and in the majority of circumstances it was indeed a snake oil thing. Asuitable set of controlled experiments would be needed to prove this.
I am, as yet, not convinced by the theory (maybe I have missed something) and I am not aware of robust experiments to prove or disprove - Snake Oil or not, I have no idea, there might be something I am missing.
I do to some degree agree with @ebee if I had a cylinder without the boss for an immersion heater, then the Willis would seem a cost-effective method, and with solar water heating, it also seems a good idea. But to rip out existing and replace with Willis that seems unlikely to have enough benefits to be worthwhile.
But we do know in Ulster it works, and has done for years.
The voltage optimisation was very good with wire wound fluorescent lighting at reducing the power used, but not stopping them striking, with the replacement of the wire wound ballast with the electronic type the benefit evaporated. We did have auto transformers on our tower cranes which were 380 volts, when we were 415 volts, but with harmonisation when we all went to 400 volts, again no longer required, even auto transformer starters, have in the main been replaced with some form of inverter starter.
Some people do try cheating with them 1771677657938.png trying to defeat the over-voltage protection built into solar panel inverters, can't believe he told the world what he had done, doing it is one thing, but telling everyone that is something else.
But I look at my errors, and hind sight is good, I should have not fitted iboost+ as with the voltage optimisation, it was a good idea, when we got paid for export based on the size of the installation, not on what we actually exported, with feed in tariffs being reduced we may return to a time when they help, but even after March 12p/kWh for export and 8.5p/kWh for off-peak, still better heating DHW over night rather than using solar.
In winter my central heating boiler heats DHW, can't stop it. 1771679073798.png1771678865362.png so the immersion does very little, summer clearly not the same, 1771679257911.png as central heating not running, but at 12p/kWh lost payment, 87p and £4.16 for the month, any device to improve DHW would need to be rather cheap. We are looking at around £35 a year to heat DHW or less.
