Bathroom extractor fan what to do poor job
2 Jul 2024
I've just spent thousands having a new bathroom installed. I can't fault the plumber and tiler but they arranged for an electrician to fit the extractor fan and he has left it like this. He is blaming the plasterer and claiming the wall is not level. I have checked and that's not really true. Also, he left a cable clip exposed. If I can't get the electrician to return, how best to hide the gap?
Did you employ the electrician or did the main contractor?
Your first port of call is with the person you gave the job to
More likely to be the duct not installed properly if it goes through a cavity wall.
I'll bet it is a solid duct in the wall and it has been core-cut at an angle, making it impossible to fit the fan flat to the interior wall.
If that is the case, the duct hole should slope the other way....
But I agree with Sunray, its not your problem to sort. Very bad workpersonship.
Ahhhh the mysterious case of the duct not being square....
A situation I found in one of my rental properties, my solution was to cut one side off the fan spigot. I discovered the old spigots were smaller and more tolerent to misalignment.
Why is this extractor installed at all - wall clearly not painted or finished in any way, neither is the ceiling.
Is this one of those affairs where decorator imposters come in later and slap emulsion paint over everything?
Questionable location for the isolator on the adjacent wall.
Can see daylight through that extractor. That’s going to be lovely in winter
Think your spark might have been a bit of a muppet
Needs a least an automatic louvre on the outside, to prevent the wind blowing in, when the fans not running.
Too late now, but we always try to avoid wall fans where possible. High quality in-line fans are more powerful and a lot quieter/ no back draughts etc.
Where has the draft gone then?
I recall it was a common complaint.
If a proper automatic shutter is fitted, then there will be no draft from either type of fan.
Yes but
Too late now,
quite frankly have no idea I have no idea wherethis:
comes from
and this:
Seems to say wall fans are draufty but isn't an issue with in-line fans.
My historic experience would have at least placed them on an equal footing
Why not, decent inline fans offer superior airflow through the same size duct, reduced sound levels and a longer duct run will cause additional restriction from backdraft compared to a 1' pipe through the wall. One of the first jobs I did when I moved into my current house.
