Wow...more than I thought. Probably best I consider a repair of the rotten timber then?
I could fit you in tomorrow.£1.50
Andy
Clueless.A perfect, easy opportunity, to learn to lay bricks yourself. £30 for materials, on top of the bricks you said you have. You are on site, just an easy days work. All you need is a lump hammer and chisel, to ease the 1/2 bricks out, a long straight edge, a brickies trowel, sand, and cement.
Lol.I had about £300 in my mind, for a days labour you supplying the bricks, they do all the work inc toothing in the bricks.
Staple some polythene over it and save yourself a fortune.Wow...more than I thought. Probably best I consider a repair of the rotten timber then?
Thats not even a full days work, if any brickie dragged that into 2 days work, they'd be taking the pi%$.Clueless.
Lol.
It will take a day to get raw materials, bring and set up the trestle scaffolding, mixer, barrows tools etc, set up, remove the window, fix wall starters etc to the inside, tooth out the bricks (fingers crossed no collateral damage), lay the inner leaf with tie wires etc and another visit to finish the brick up the outside, doing all the header cuts and struck pointing etc, clean up and remove the gear.
£400 is a bargain, even if it was just the outer leaf.
Now you know how nosey spends half the year at the Après-ski.Thats not even a full days work, if any brickie dragged that into 2 days work, they'd be taking the pi%$.
My aprés these days is a good book.Now you know how nosey spends half the year at the Après-ski.
Deffo less than 24 hours - correct.Thats not even a full days work
I'd do 4 or 5 in 24hrsDeffo less than 24 hours - correct.
