Cost for bricking up a small window?
Wow...more than I thought. Probably best I consider a repair of the rotten timber then?
A perfect, easy opportunity, to learn to lay bricks yourself. £30 for materials, on top of the bricks you said you have. You are on site, just an easy days work. All you need is a lump hammer and chisel, to ease the 1/2 bricks out, a long straight edge, a brickies trowel, sand, and cement.
Patching the window, you will be patching it again next year, then the next.
There's an alternative way to brick in a window without cutting out any bricks.
You set the new brickwork back about an inch or so, so it's recessed.
It's seen as an architectural.feature, and is sometimes done on new builds. It's a feature that mimics the old houses with bricked up windows because of the window tax.
As has been said, have bash at it yourself it's a fairly easy project to start with and as it's out the way won't matter if it's not perfect.
Another option is to measure up the opening and keep an eye out on ebay or the like for an old upvc unit that's about the right size, you can get upvc add ons to make a slightly smaller window fit a bigger opening.
