Tyre Rotation, any point?
8 Jul 2008
Derbyshire
I was musing rotating my tyres as I've done about 6000 miles on this set (all from new).
But I keep seeing differing opinions, with a quite a few saying that for modern cars, rotation is not as needed or as useful as it used to be.
Should it be as simple as (for a FWD car) fronts to the back and rears crossover to fronts?
Or are there other factors that could come into play, such as wheels now not being balanced for their new positions. Or, if wheels are balanced should they stay correctly balanced regardless of position.
Again, I have seen videos saying other issues can crop up with camber and balanced when trying to rotate tyres.
Thoughts?
Do you want all 4 tyres to wear out at the same time or would you rather spread the cost by having the fronts wear out at a different time to the backs?
Do you do enough miles to wear back tyres out before they start cracking and need to be replaced anyway?
Personally I don't bother.......on FWD vehicles I keep the best tyres on the front, maybe putting them on the back depending on wear. I don't mix up offside and near side.
Balancing won't be affected, unless in a rare occasion the wheel is balanced on the hub. Camber wear shouldn't be evident these days so long as the vehicle hasn't been altered in any way.
On some cars, a brand new tyre on the front N/S for example, paired with a worn one on the O/S may set the tyre warning lamps on - if governed by the ABS system.
4WD vehicles may have special requirements for their tyre replacement.
Observe the tyre rotation markings, if any!
Wheel alignment checks are a good thing.......maybe yearly.
John :)
According to my service records, the tyres were wearing pretty evenly, with more slightly more wear to the fronts.
But what caught my attention today was that the inner of the front driver's side looks moderately more worn to the inner than the front passenger side.
I have no issues with pulling (under acceleration or braking) and alignment was last done at the tyre change (albeit at kwik fit, but that was not my choice).
So, until I get to the bottom of it, I was just pondering rotating them to buy me more time.
I don't bother, my old 5 series (RWD) wears it's tyres very evenly. After 24K miles the Michelins still have at least 5mm tread depth.
Interestingly the current industry advice seems to be that the best rubber should be fitted to the rear, regardless of whether the car is FWD/RWD
nb. my old RR classic is perm. 4x4 & again wear is consistent.
We used to shuffle tyres around.
The tyre company our lease company uses won't do it. Our rears wore down to 2mm just a bit over 21K. The fronts are still fine at 27K.
You may have guessed it's RWD.
The factory fit tyres were EV ones.
That's some disparity in wear, never encountered anything like it in my 62 years of car ownership.
Suspension problems, vehicle design or driving style?
I believe some EV tyres start life with less tread than others, 6mm.
No suspension issues, it's a 3 year lease car with maintenance that has 4 months to run.
A lot depends on the car.
My old Alfa, it doesn't matter hugely, but it runs a bit of toe-out (it's supposed to) wear the inside edges of the front. (Also a bit of negative camber as standard). I can get a little bit more out of a set by swapping front-to-rear part way through life. The tyres it's on at present aren't directional, so I can swap diagonally, as well as front-rear.
My EV eats its rear tyres on their inside edge because it runs a shed-load of negative camber. It's done so from new - in fact, I'm on my second car and they both do it from new. Typical performance BMW setup. Also, with it being an EV, most of the "everyday" braking is done by the rears, as well as all the traction. No chance to rotate them as they're asymmetric and the fronts are a different size to the rears. Fronts wear quite evenly.
The old Freelander 1 is typical small 4x4 and really finnicky about tyre diameter. Received wisdom from Freelander 1 gurus, is to use the same make, model and pressure of tyre and both ends, and always have the best ones on the back. Handbook used to recommend swapping front-to rear every 3000 miles, I think!
Wife's Skoda (also 4x4) has summer and winter tyres on two sets of rims, so they get rotated twice a year when I swap from one to the other as a matter of course.
Some high performance tyres start with less tread on them, because the manufacturer wants to keep any "vagueness" due to tread block distortion to a minimum. My EV is on "ordinary" high performance tyres, rather than EV-specific.
