Long screws - recommendation
9 May 2021
Hello
I am in the need of about 5 extra long screws for wood/outdoor that is suitable for 4mm or 6mm pilot holes, that is a length of 200mm. Can do a bit shorter with counterbored holes where needed and anything too long I can trim down.
I only require 3, but I am after not much more than 5 due to any breakages.
The minimum amount I can find is around 20-25 with high costs > £15 - cheaper the better here.
Do you know where I can find these screws?
eBay - Jones DIY sell pack of 10 6mm x 200mm wood screws for £7.49 inc P&P. It was the first one I found... Sure there will many other sellers on there...
Or find an old fashioned Ironmongers or timber yard that might keep and sell split packs of screws. Giving your (approx) location may help with suggestions.
Do you have a 200mm+ 4mm drill bit for the pilot holes? And do you mean pilot holes or clearance holes?
And can you not use long coach screws?
Thank you.
I had checked all my local stores that should sell screws, there was a couple that didn’t.
I get easily distracted and find myself looking for one thing then 4 hours later I am somehow reading something like a battle of world war 2, to my head having a problem with accepted science, like unable to travel faster than the speed of light but folding space is accepted…
I have brought some extra long screws now thank you, I hope they won’t take forever to get here from eBay.
As far as I can tell there is only one independent timber yard around me, “Solent city” area. They don’t seem to sell anything like screws and a lot of their timber has plant life growing on it.
I have some really long drill bits as of last week, 4mm ø x 200mm, 4mm ø x 400mm and 6mm ø x 400, and some other long bits either on order or already have.
Lol… I am such a fool… not sure what my brain is doing most of the time, maybe pain/morphine maybe autism maybe a complete miss reading of the measurements… I need 350mm minimum length, maybe some sort of pocket hole job…
You see my tiny workshop started to leak, but that leak got worse and worse, as the water was getting in via the overlapping corrugated clear sheets, going upwards, I thought this would be fine. It means that I had to rebuild a new roof for the area, using the old sheets, I built a frame On the ground, then took the first row of sheets then the next row, adding rubber seals, rubber waterproofing tape, silicone and water resistant spray foam. With better guttering we put the new roof on top of the old roof frame, so now we have 2 3x2’s layered with the 3” side facing upwards, with the door opening added which is 2” and then added 5 inch blocks with another 3x2 underneath that.
With all of this, I have the new roof frame, old roof frame, the door frame a spacer and another frame.
New roof frame 3”
Old roof frame 3”
Door frame 2”
“Door spacer” 5”
Door opening frame “2
Total being 15” of wood to be needed to be screwed down. As I can’t screw through the roofing sheets.
I am getting pictures in a few minutes, with a sketch showing what I mean, and why I designed it this way.
Why not? There are seals available for screw/nail heads.
I am disabled, my legs don’t work properly, they think autism related, I can’t do much, and what I do manage to get done takes me a lot longer than it should. That’s if my body can handle the stress/job, else I have to wait until my body is ready.
I am disabled, I am allowed to walk around the house without my aircast boot, but if I go outside for any reason I must wear the boot as it protects my ankles. You see “they” (my case went to the top orthopaedic surgeons in the country, they only really come together for extreme cases our military personnel who had their leg blown half off) who think my autism and sensory disorders somehow forced my body to basically twist out of shape.
The only “fix” is if they break my hips, stick a lot of metal plates and rotate them inwards, then break my ball sockets on my femur, break the femur in 2 places before breaking the femur right by my knee and again rotate inwards and bolt everything down with metal work, they then want to break both my tibia and fibula in 2 places and again rotate inwards with loads of metal bolting everything. They want to rotate everything about 11° each, and with this method I should be able to walk unaided. They would do both my legs at the same time, with my hips (one surgery, the top of my femurs (both legs in one surgery), fewest surgery’s as possible, could take 3 months to complete all the surgery’s, with a total recovery time of 3 years, but would become taller by 4-8 inches. However my hips are not only out of alignment on the Y axis, but also on the z axis by 2° meaning it will be too much of a risk, I can’t point my toes to be directly in front of me, but I can point my toes to about 4 o’clock - 120° and my left leg/toes to about 230°.
I take a lot (high doses) of morphine every 12 hours with a “top up” for when I need to do something (take a bath, shopping or anything that involves my feet and ankles). I can’t “easily” go upstairs, including slight slopes, can’t go up ladders, escalators especially the ones that take the trolley too.
From 2007 until 2019 I had surgery mostly on my right ankle or my left once a year or 18months or so, then covid/brexit and the deep internal bracing seemed to have an affect and I did okay but pain was not reduced. In 2024, I again sprained my left ankle and I knew I broke something. My GP did X-rays but an untrained admin saw my x-ray results and basically deleted it was “I should be in a lot of pain if it was broken, all she had to do was open the file, my right ankle/foot is so painful that if one of my cats hair fell onto my foot, it feels like a red hot scalpel slicing my foot open.
really good link there
and well done for sharing as it helps others understand that "normal" is no such thing other than people that are similar to you so many many many different types off"normal"
:giggle:
