Yes, unfortunately you have to use a 3rd party site, eg YouTube. Maybe post a photo of inside the cistern?I've tried to add a video but the site wouldn't let me. Thanks
Alex, can that be fixed in not a plumber lolFlush valve leaking; or water level too high and internal overflow operating.
The water level is not high it's not really getting very high at allAlex, can that be fixed in not a plumber lol
If the water isn't overflowing then presumably the flush valve is leaking. Post a well-focussed pic of the inside of the cistern and someone here will likely recognise the flush valve brand and advise on its treatment/replacement.The water level is not high
Thanks, any ideas what's wrong with it?Looks like an Ideal Standard/Armitage Shanks
Then it looks as though the fill valve is at fault and the water level rises until it reaches the overflow 'window' in the flush valve.if I lift the float (yellow dot) it stops but within a minute or so it starts again
Thanks, is that easy to do, it do I have to take the close coupled bit of the toilet off to do it,Then it looks as though the fill valve is at fault and the water level rises until it reaches the overflow 'window' in the flush valve.
Not usually, but it depends on the design of the pan. A photo of the bottom of the fill valve on the underside of the cistern would reveal all.Thanks, is that easy to do, it do I have to take the close coupled bit of the toilet off to do it,
