Shaver and toothbrush sockets
I bought a bathroom mirror cabinet in the UK years ago that had a shaver point built in. It didn't have a transformer. I didn't use it and instead installed a regular one adjacent.
Much later, I removed the non compliant socket when upgrading the flu fittings in the cabinet to LEDs.
The reset of the world manages without (big, heavy, humming, hot) isolation transformers. So common sense would say they are no longer required. In was a cleaver idea in its day.
And as for the regulation being all about Baths, as long as you aren't fitting a 13A socket, then you aren't going to find an appliance with a 2 pin connector and cable long enough that will reach a bath
Whether they are (or ever have been) really 'needed' is, I suppose, debatable - but what do you think has changed simce "its day" when they were a "clever idea"?
Modern ones and maybe even old ones too, have switches activated off the shutters, to prevent the transformer running
Indeed -and some had a little button which the plug pushed against to activate the switch, rather than using the 'shutters'.
Whic frequently got wedged in so it worked :cry:
but what? If anything plugged in is going to press the button, why would anyone ever need to 'wedge' the button?
1/ Because not all plugs had a flat bum
2/ Because not all plugs held in tight
3/ Because the buttons became very 'sensitive'/intermittant
4/ Because the 'double button' arrangement for 240/120 sockets was always 'iffy' and jammed
I have one such troublesome unit which was replaced - reconfigured it to bypass the switch, and for a couple or 3 decades it has been supplying 2 CCTV cameras as an IT supply .
Yes, both. It’s a bathroom!
it makes a big difference. Quite a lot of people call the room with just a toilet and sink in it a “bathroom”. And the electrical regulations for that room are very different for the room that has a toilet, sink and bath or shower.
That’s why we kept asking for clarification.
Your any socket in your room needs the isolating transformer or to be placed more than 2.5metres from the edge of the shower and/or bath. It doesn’t matter if it’s a regular uk socket, or a European one, etc.
There’s no wiggle room on that.
