- Joined
- 13 May 2021
- Messages
- 149
- Reaction score
- 6
- Country
I have a building in the garden, which was originally a single garage, the brick wall is the original left side wall, the original right side brick wall was knocked down, and the rear original brick wall was then extended and joined with concrete heavy duty blockwork to make it a wider building, then the side wall was built from blockwork
None of this by me
What I want to do is finish this off. The building has a 5.7m span both ways. Therefore I will split the roof with an RSJ to reduce joist lengths and thickness. To sit the RSJ I need a pillar on the brick wall to mirror the concrete block one shown.
Can I use frame cramp wall ties on the brick wall and then use upright positioned blocks to build out a pillar for the RSJ?
Any help taken!
