I note
eFIXX has talked about this problem with over voltage and EV chargers cutting out, and using current in the earth wires as part of the detection for loss of PEN.
I am not sure about having a relay/cut-out which can disconnect the earth? Same with a diode in the earth wire. To my mind if you need to fit earth rods, as well as use the gird earth connection, then we have a problem with testing to ensure they work.
Be it an all singing dancing loop impedance tester, or a simple plug-in socket tester with loop, we are one looking at £50 or more, and two relying on it actually finding a fault. The earth rod testing kit, needs one to put in test probes quite a distance from the rod under test, one moves the centre probe to see if one has selected enough distance. I think I could just about test in this house, but very few domestic premises can one get probes in at the required distance.
When my panels were fitted, the electrician showed me the earth rod was 1Ω. This is extremely unlikely, he must have disconnected a wrong wire to test, I have fitted 100s of earth rods, and to get 8Ω needed between 3 and 8 rods. So unless his rod was very close or hit some underground metalwork, that reading seems impossible for a single rod.
There is a relay in the neutral, as with loss of grid the neutral needs disconnecting before it is connected to local earth. But as to if my inverter measures earth to neutral or any earth current I would think unlikely.
So as to detecting loss of PEN, I am not sure it can do that? It will disconnect with under and over voltage, but it seems there is a move to change for -6/+10% to +/- 10% and if this happens, then using voltage to detect loss of PEN becomes a problem.
It seems with AC, we allow 50 volts arm to arm, and 70 volts arm to leg, not sure how that works? As we are not the only animals which can roam the streets, and I am told 25 volts can kill a cow, getting up in the morning to find a dead cow leaning on your EV is not something I want. OK here only tend to get sheep, badgers, foxes, squirrels, and cats. But don't really want to deal with them either.
Remember we don't all live in towns with no wild life. Lambs bleating did before double glazing change, wake me up.
The problem stems from allowing the use of a PEN, but that is unlikely to change in a hurry. But we are also looking at the size of an island, with a pole transformer with half a dozen homes, I would expect solar inverters to close down. But with a sub-station feeding 100 homes, we are looking at a different situation. If there are any motors these can smooth out the AC wave form, I remember working on the Falklands where we would run the shearing sharping wheel all the time the shearing was going on, as it acted as a reservoir to take the start load of the shears. Non inverter fridges and freezers will do the same, so the delay of the auto re-start of the inverters has to be long enough so they allow the voltage to decay before trying to re-start.
I note my inverter has an array of dip switches to allow it to comply with many countries rules, even G98 and G99 need a different setting. So the only way to ensure an inverter complies with British rules will be to have the 13 amp plug fitted to the inverter, or something in the 13 amp lead with sets the inverter to comply with British rules.
This means, until the rules are published, no one can make inverters to comply with British law, as we simply don't know what it will be. In the meantime, we have people jumping the gun, and buying and using plug in solar.
What would be interesting to know, is does the electric meter alert suppliers when there is unlicenced export? Yes with a smart meter they can detect export, but does any device send an alert which energy companies can act on?
