RTS turn off
That may be bureaucratically true, but that certainly is not technologically/literally true - you could, like me, have a 'dumb' dual-tariff meter.
Or two meters? One for normal and one for off peak run by a time clock such as the old mechanical one you mentioned?
Sure, but we've "moved on" from that to equivalent but 'more convenient' solutions.
In my present home, I've always had a dual tariff. It started with an 'external' electromechanical time switch and two meters. It then moved to a single dual tariff meter, still controlled by the external time switch. 'Finally' (i.e. 'still now') it changed to a single electronic dual-tariff (still 'dumb') meter with some sort of internal clock, hence no need for an external time switch.
The next, and, I suppose, 'really final' stage will be the ultimate change to a 'smart' meter - but, as I've said, there certainly is no 'need' (other than a bureaucratic/policy one) to have a 'smart' meter in order to have a dual tariff.
Yes I have an export meter which has never been used. The system was simple, the supplier can't force anyone to have a smart meter, but if you refuse, they can also refuse to allow dual tariffs or export payment. So to refuse is to cut off your nose to spite your face.
I know someone who still has two meters and a mechanical clock and gets a afternoon boost on the off peak
I knew someone who moved into a house with a dual rate meter controlled by a timeswitch and NSH's who complained bitterly the heating was useless/unpredictable and constantly having to 'top up' during the day. The discovery by Sunray that each heater contained a mechanical time switch which only ran for the duration of the contactor being operated was predicted to be the source of the confusion...
Sunray bypassed the timeswitches which if anything created a worse situation and a bill increase and more confusion.
It turned out it was a very old 'heating plan' system (possibly E10?) and the timeswitch settings had the cheap rate for most of the day,
However there was a second timeswitch operating the contactor; for something like an hour during the night (peakrate) and again during the day, for part of which the meter didn't register anything (a third rate not enabled??)
Back in those days I had no idea about any of these plans and made my discoveries by using a slow speed video recorder (CCTV) and camera watching the meter etc.
I advised them to get it sorted out and call me back to sort out the heaters if needed.
