That may be bureaucratically true, but that certainly is not technologically/literally true - you could, like me, have a 'dumb' dual-tariff meter.Since I did not have a teleswitch, only way for me to have a dual tariff was a smart meter.
Or two meters? One for normal and one for off peak run by a time clock such as the old mechanical one you mentioned?That may be bureaucratically true, but that certainly is not technologically/literally true - you could, like me, have a 'dumb' dual-tariff meter.
Sure, but we've "moved on" from that to equivalent but 'more convenient' solutions.Or two meters? One for normal and one for off peak run by a time clock such as the old mechanical one you mentioned?
Yes I have an export meter which has never been used. The system was simple, the supplier can't force anyone to have a smart meter, but if you refuse, they can also refuse to allow dual tariffs or export payment. So to refuse is to cut off your nose to spite your face.That may be bureaucratically true, but that certainly is not technologically/literally true - you could, like me, have a 'dumb' dual-tariff meter.
I know someone who still has two meters and a mechanical clock and gets a afternoon boost on the off peakSure, but we've "moved on" from that to equivalent but 'more convenient' solutions.
In my present home, I've always had a dual tariff. It started with an 'external' electromechanical time switch and two meters. It then moved to a single dual tariff meter, still controlled by the external time switch. 'Finally' (i.e. 'still now') it changed to a single electronic dual-tariff (still 'dumb') meter with some sort of internal clock, hence no need for an external time switch.
The next, and, I suppose, 'really final' stage will be the ultimate change to a 'smart' meter - but, as I've said, there certainly is no 'need' (other than a bureaucratic/policy one) to have a 'smart' meter in order to have a dual tariff.
I knew someone who moved into a house with a dual rate meter controlled by a timeswitch and NSH's who complained bitterly the heating was useless/unpredictable and constantly having to 'top up' during the day. The discovery by Sunray that each heater contained a mechanical time switch which only ran for the duration of the contactor being operated was predicted to be the source of the confusion...I know someone who still has two meters and a mechanical clock and gets a afternoon boost on the off peak
Just searched and google said turn off in June. I will see overnight if the night rate is still spinning on meter.If anybody's still interested, my RTS was switched off about a month ago. Unsurprisingly, it froze in day mode.
That sounds fair enough to me ....... The system was simple, the supplier can't force anyone to have a smart meter, but if you refuse, they can also refuse to allow dual tariffs or export payment. ...
Well, yes, IF you 'refuse' - but why not just accept the 'smart' meter?... So to refuse is to cut off your nose to spite your face.
Such a system certainly persisted here for a few years before they eventually 'upgraded' it to a dual-tariff meter (and an external mechanical time switch).I know someone who still has two meters and a mechanical clock and gets a afternoon boost on the off peak
30 June 2025 was the cut-off date. Government press release said date delayed It would start 30 June 2025 but on 30 May 2025, there were 314,935 RTS meters requiring replacement in Great Britain, according to supplier data collected by Ofgem.Just searched and google said turn off in June. I will see overnight if the night rate is still spinning on meter.
Which should not have been required, his meter should have been updated before the RTS signal stopped.Though at some point I might succumb to the pestering to have a smart meter.
clearly he should have heard before the turn-off. As to if he will benefit from a split tariff is another question.They said the engineer would decide when he came, but I've heard no more since.
one has to enter the MPAN number, Ofgem says
which is less than I am paying, so once you sign up for a split tariff, one needs to be sure your using enough off-peak to ensure it is worthwhile. My battery charges overnight, and my daytime use is either from the battery or solar, since if I did not use the solar, I would get paid 12p/kWh for export, I do not need to worry, I can fully charge my 6.4 kWh battery overnight, even if it then has no room to take the solar in the day.
if I was to use Flux, then I would need to be careful not to run out of battery between 4 pm and 7 pm, and I simply did not want to control my life around when I use electric.Google:30 June 2025 was the cut-off date. Government press release said date delayed It would start 30 June 2025 but on 30 May 2025, there were 314,935 RTS meters requiring replacement in Great Britain, according to supplier data collected by Ofgem.
Yes, that's what I used. But it saidGoogle:
All depends on which report one reads.There will not be a mass switch off of the RTS national signal on 30 June 2025. From this date, a phase out will begin of the RTS functionality for small groups of meters at a time. Customers will be informed directly.
What does "extract their digits" mean?So any with RTS that haven't taken up a smart meter install offer need to extract their digits and do so asap.
