How to approach laying a path here
Is that really all the wall footing, or did it just overspill its trench at the top?
I'd have a dig alongside it, if there's nothing under the widest bits then slice them off with an angle grinder. Aim to get slabs in alongside the concrete, with a gap between them and the wall. Make this gap the narrowest you could reasonably slim it all down into, I'd guess 100mm which would be a normal-looking typical sized gap. Then put an inch or two of 10mm gravel in the gap over the concrete. You could get away with slicing/grinding downwards on the surface of the deeper wide bits, just to give enough height to cover it all with gravel without it peeking out.
Get the slabs central to the gate, then it will look right, like it was meant to be there.
Wife picked 20x20 porcelains. I've got a big bag of type 1 coming and half a big bag of ballast for haunching in a run of concrete edges to the left side of the photo.
Tiles going down with fibre reinforced mortar slurry primer on the back of the tiles.
The depth of the exposed concrete in the photo is over 6" so I stopped digging there and, yes, presume it's all footings.
Currently planning to tile over it and right up to the wall since putting a 6" gravel strip doesn't seem to work.
Now would be the time to make a new plan if that's going to cause damp issues but, again, it's an open cart lodge with DPC at the top of the bricks......
I know I've been told further up this thread to just crack on with that it so can imagine some future surveyor telling me, when I come to sell, that its wrong and could cause damp etc. Perhaps I should tank/bitumen along the wall at the finished path height?
I'd use DPM to stop weeds in the future, some will grow anywhere.
It won't make a difference if weeds get a hold of the garden - roots will work their way under the slabs and matting.
Better off keeping them under control with weed killer.
You are well below the threshold for DPC breach.
My only criticism would be of the bricks themselves and their frost rating. It might be an idea to coat the bricks with some Stormdry protection cream, if they are a bit chalky.
Thanks.
Inside of the wall pictured below - note DPC at ground level and also at the top. Seems odd to me.
External paving will bring the exterior level up to one brick above the lower DPC but well below the upper one. Until recently their was earth heaped all along here (half way up the wall) but I dug it back, cleaned up the wall and have already coated with masonry cream.
Load bearing on these is fine - I've got a path at the other side of the house which I laid with these 4 years ago with no issues.
20mm porcelain. Going on a 25mm bed of reinforced mortar (with priming slurry on the back of the tiles) and that'll be on compacted type 1. Am edging with 50mm concrete edgers.
If they're lapping over the concrete then they're going to have a rigid base on one edge, while the compacted rock beneath will inevitably sink over time.
They'd be OK on concrete or on compacted rock, but not spanning the two.
