- Joined
- 24 Nov 2004
- Messages
- 465
- Reaction score
- 7
- Country
Thanks.thought I ought to mark the occasion ... not that anyone cares
well it also covers PMR466 and we have two other radios which we did use on the push bikes, we found something which recived the message without needing to stop to answer it was good. So my chain has come off, will you wait for me, or my chain has broken will you return to rescue me, was handy.Both eBay and Amazon, to name but two, seem to be currently still offering a good few.I made a crystal set as a lad, the unit needed a high impedance earpiece and in latter years their supply seems to have dried up.
A BFO was not exactly rocket science, and one didn't even need one to receive SSB if one was using a ('frowned upon') receiver with a 'regenerative' RF stage.... but we lost the ability to listen to radio hams due to use of sideband, and VHF due to use of FM, I do have one radio with a BFO which will receive sideband, not used it in years.
A tuned circuit, per se (and 'alone'), obviously could not create a waveform of any frequency - whenever you saw something on your scope it must have been 'picking up' something from somewhere!..... A couple of months ago I decided that I really ought to make a crystal set before this was turned off. .... I did get a ~ 200 kHz signal on my scope's most sensitive range (about 30 mV RMS I think), but I couldn't see much modulation. And tellingly, if I changed the capacitor I could see a 250 kHz or 150 kHz waveform with about the same amplitude - so basically, I'd built a tuned circuit with about the right resonant frequency but it wasn't actually picking up the Droitwich signal.
Sure. I've never lived particularly close to any broadcast transmitter, so my crystal sets invariably needed a 'a ferrite rod and long wire aerial' (and I think the same was true of the earliest 'transistor radios' I built, although some of them may have managed with just the ferrite rod!I then looked more carefully at the website that I'd got the plans from, and it turned out that the author lives about 20 miles from Droitwich. In contrast, I'm about 300 miles away. So my chances of it working were slim! I guess I could have made it work with a ferrite rod and a long wire aerial, but it's too late now.
I certainly do,but I'm pretty ancientWho else remembers the R4 emergency personal messages?
I'm not sure I get that. A superhet won't have any oscillator running at IF frequency (unless the oscillator IS "its BFO").My dad and I used to listen in to SSB transmissions placing a second, superhet receiver close to the main receiver, tuned so that it's IF oscillator acted as the BFO.
Indeed. All very true.The second set has a mixer oscillator that runs 465kHz (the IF) offset from the frequency being received, to create the IF signal which is then filtered, amplified and demodulated. That Oscillator radiates and some of that is received by the set receiving the SSB signal.
Yes, there will be plenty of places (not the least being the mixer itself of the first set) where sums/differences (and harmonics) could be generated, but this is where I'm struggling a bit (probably because I'm being dim - or not yet recovered from the effects of the recent heatTune the second set correctly and non-linearities in the first set circuitry ( there are several places where they often occur) results in sum and difference frequencies which replace the missing carrier ....
Indeed - because one sideband is all one needs. The second sideband is merely a mirror image of the other one, so conveys no additional information (although, I suppose, it does provide 'redundancy'), whilst the carrier itself conveys no information at all - hence SSBSC carrier is much more 'efficient' and, since it is 'SSB' takes only half the bandwidth. Do you recall that some people played with DSBSC - still more efficient than standard AM, but no less 'wide'?(SSB being short for SSBSC (suppressed carrier)
Yep. One obviously doesn't hear much (if anything!) of CW without a BFO unless there is a reasonable amount of 'noise' about (for the 'marks' of the CW to 'silence')!And yes, we used it to listen to CW too, so I learnt Morse.
Anyone want to buy a 500+kw transmitter and a set of large HF antenna masts, used but in VGC?![]()
