Broken clay gully/trap - What to replace it with?
29 Aug 2017
Son-In-Law is renovating the patio area at the back of his house and restoring the surface to be at the correct level (2 bricks down from DPC I believe) by removing all the additional layers that have been added over time. He may (or may not) have damaged this clay gully/trap that would have been installed when the estate was built sometime in the 1960s. The gully/trap appears to have a vertical outlet into a 90 degree bend connected into the soil/waste system.
Ignore the plastic pipe, it's a temporary bodge to take waste water from the kitchen sink and washing machine into a nearby inspection hatch/chamber.
Can anyone shed any light on the make/model of the gully/trap and how we might best replace it, and what with. The vertical outlet from the gully/trap is cemented into the collar of 90 degree bend, so is probably going to be tricky to remove without causing further damage, so and advice on how to do so would also be greatly appreciated. I've attached a sketch of the rough dimensions of the gully/trap
Time for a new gully, a roddable bottle trap type seems the best option. Laying a new patio is the ideal opportunity to get the levels right. Clay to plastic connectors are available
Yes. I'm also thinking a bottle gully with a square/rectangular grille and a 90 degree bend into the collar of the clay pipe. Just a question of whether I can make the dimensions work, whether I can separate the existing components without breaking anything else, and whether there is a 90 degree fitting that is suitable to fit into the collar of the clay pipe. More googling to do and a visit to some local builders merchants here in Newport tomorrow.
Piece of cake...
(y)
We seem to be making progress. After trying several other combinations of fittings, it looks like we can get everything to line up. I've had to cut away part of the clay pipe collar in order to fit the 90 degree drain adaptor. A straight drain adaptor with a 90 degree bend would push the bottle gully way too high for the intended finished surface level.
Plan tomorrow is to make a concrete pad for the bottle gully and then cut a short piece of 110mm pipe to connect the 90 degree McAlpine Drain Connector to the 90 degree bend from the bottle gully.
Any recommendations for suitable material for filling the collar of the clay pipe? Cement, Silicone, Soudal, Nothing, Something Else?
Sharp sand and cement 3:1
Be careful as it will be a brittle connection, unlike the more flexible Fernco coupler shown above. Make sure you have it all connected up and rigid before mortaring.
