Hi
Some sanity check please.
Our builder has just downed tools. Costs were ballooning and we wanted to know why but the final straw, his final walk off argument, is it's our fault we can't make up our mind and keep interfering.
Long story short do 7.3 concrete blocks need thicker joint. ?
We'd agreed the height of our garden retaining wall, he laid 3 blocks on the floor without cement and the surface brick on top for the decorative effect. The height looked ok. I assumed the joints would be about 10mm so +40mm was good.
He's actually laid the blocks using joints an inch thick, over 3 courses + the to brick that's way higher than we wanted.
Last night I got home and realised it was not what we wanted so as the top block was laid on it's side ( top layer of decorative bricks not laid) and the joint was still wet I figured as that matched the height we wanted then take the top off
He'd only laid 20 blocks so I did it, took them off, cleaned it up well and ensured all was ok.
And now as a positive there's 2/3 less blocks to lay.
He came in this morning and went nuts. I took today off because I knew this would happen and didn't want my wife here on her own.
He said the joints have to be thicker to support the heavier block.... so I asked why, houses aren't built with thick cement at the bottom.
Keep interfering, don't understand, etc...
So if I'm wrong please tell me. I hate this conflict.
Pg
Pg
