but he wont say how.![]()
You shouldn't mock noseall until you've walked a mile in his shoes.
No need to mock boyo. It makes you look an even bigger tw@.but he wont say how.
I'd also hazard a guess that a skilled sailor would navigate it easier with a sail only powered vessel.Depends what other conditions they are combined with.
Tidal currents can be favourable or unfavourable so yes, it can make a difference.
At least I'm not a Trump fan. Testicualr cancer, being crucified, eyes removed with a spoon, would be more appealing.You shouldn't mock noseall until you've walked a mile in his shoes.
If I was tasked to assist, did not fear piracy, had capacity etc, I'd take them back to France
Provided it is for good reason
Which is exactly the point.
- 1/3rd of their key south coast stations call outs are to assist illegals. It's a significant cost, one that their books show they could do without.
are you seriously trying to suggest the above is a claim that
"the RNLI is to blame for the spectacular rise in immigration"
- their non-police status and willingness to help encourages the gangs.
What is an Illegal?
Thats not how it works - your boat sits on top of the water and moves with the tide. You don't fight it. Wind and tide in the same direction makes the sea calmer, because the apparent wind is lower and the waves get flattened. When a slow boat crosses the channel they typically follow an S shape as the tide takes them one way and then the other way. If you expect it to take ~6 hours and you have 3 hours of flood followed by 3 hours of ebb, they will pretty much cancel each other out. Particularly in the Dover straits where the streams go from 0-3kts fairly uniformly. There is nothing complex about creating a passage plan to cross the dover strait. Portsmouth to Cherbourg is a different challenge, but still not particularly complex.No need to mock boyo. It makes you look an even bigger tw@.
I'd imagine that if the tidal current AND the wind are in the same direction, and you are in poorly powered vessel, it makes the route across The Channel a vey difficult one to navigate by eye. I'd hazard a guess that in an overloaded boat and a weak engine, most of the effort would be fighting the sideways movement,
Motorboats are infinitely easier to drive.Hence...
not from one year to the next.Hence - tidal currents can affect crossings - especially when they are combined with other factors.
Yes. And from one day to the next. And one week to the next and one month to the next.not from one year to the next.
Pointless waffle.
stay daft if you want.
Tidal currents can dramatically affect an underpowered vessel in The Channel, significantly altering its steering control and overall speed. In narrow or constricted waterways, where water moves at its fastest, even moderate currents can cause a boat to drift sideways, miss intended waypoints, or struggle to make headway. [1, 2, 3, 4]stay daft if you want.
A sailboat can easily beat an underpowered motor vessel in strong, windy, and tidal conditions. While an underpowered engine might struggle to make headway in adverse winds and waves, a properly handled sailboat uses the wind as an engine, achieving superior speed and maneuverability. [1, 2, 3, 4, 5]stay daft if you want.
more evidence you have no clue. The links don't even support the cr*p your AI generated.A sailboat can easily beat an underpowered motor vessel in strong, windy, and tidal conditions. While an underpowered engine might struggle to make headway in adverse winds and waves, a properly handled sailboat uses the wind as an engine, achieving superior speed and maneuverability. [1, 2, 3, 4, 5]
#talkingbovineexcrementsee previous answers
Stand down - BorderForce are on task
BorderForce, the French Navy and any vessel in the vicinity as coordinated by the coastguard would act.
Its simply not true.
You are welcome to stop#talkingbovineexcrement
