Anglepoise lamp bulb socket replacement Help
20 Dec 2012
i need advice on replacing my Anglepoise type Lamp socket replacement.
The lamp is over 20 years old and when I put a bulb in it flashes as its not getting a proper connection.
Its a bayonet type fitting. I think the plastic in the bulb lamp socket has gone brittle with age.
I checked the plug etc and its all O.K.
What sort of socket do I need to replace it?
Here are some pictures of the lamp. It has a switch on the middle in the back where the holder is screwed in shown in picture 2.
As well as lifting the terminals slightly if you could give them a gentle rub with very fine sandpaper or wet and dry that would help
Have you tried a different bulb?
Lots of cheap imports have small circular connections whereas decent ones have oblong shaped connections
No joy it tried the connection thing it did no good.
Then when I tried again and put the bulb back in a bit broke off the holder and it was discoloured and brittle.
Were would I get a new bulb holder? Its not an official Anglepoise just that type.
I think you will struggle to get a replacement the same as that one unless you know the manufacturer. Perhaps if you posted a pic of the old lamp assembly someone might be able to suggest how to modify it. Other than that there seem to be plenty of cheap desktop lamps available with a google search.
