Interesting Regulation of Yesteryear
As an apprentice, if I went into the office and asked to look at the regulations, I was met with what do you want them for.
I had not realised neutral had been classed as live for so long.
Also, how the bulb had been called a lamp for so long. Which is clearly wrong when everyone else calls the whole thing a lamp, if I asked for a bike lamp, I would get the whole thing, which would fit on the spigot. Same with gas or oil lamp in a house. And we still call it a table lamp. Can't work out why the IEE called the bulb a lamp?
Lamp holder plug - An accessory for insertion into a lamp holder for the purpose of connecting to the supply a current using appliance. Note.- the use of such plugs is deprecated.
Had to look it up:- Deprecated means a feature, code, or practice is outdated, no longer recommended for use, and planned for future removal. While it still works currently to avoid breaking things right away, developers should switch to newer alternatives. In general English, it can also mean to express strong disapproval or to belittle something.
Today I would call this Ceiling rose.jpg a lamp holder plug. But google still shows 1786684726731.pngthey were when I was a lad the preferred method to power a smoothing iron, as it kept the cord out of the way. 1786685015247.png Not seen them for years either since the cordless iron.
Still have one of those somewhere that I used to use to power a drill.
In the days before battery drills were popular (and affordable), I would plug a drill into a ceiling rose when all the sockets were off.
Got to also remember thing change for a reason. Many appliances in a kitchen where often 3kw & i personally wouldn't put a 3kw appliance on a plug & would hard wire it in to a flex outlet plate. Plugs & sockets can often get warm & hot at 3kw = 13.4A at 230v. Thankfully many appliances are 2kw these days. Also, most fuse spurs where SP switching back in the 50/60's & most now are DP switching.
A previous employer ('70 thru '01) issued an internal edict that 'sheathed' 13amp plugs (ones with the live and neutral pins partially insulated) should be rated at 10amps maximum.
>>Snip<< I know at one time we had sockets which you turned the plug to turn it on, and pressed a button to turn it off, think it was a Reyrolle,
I know them as 'Electrak' plug & sockets. Ex-employer used them in 'Always On' computer areas.
"Plugs & sockets can often get warm & hot at 3kw = 13.4A at 230v."
3KW at the "real voltage of 240 v" is 12.5 amps.
Off course when that was quoted our our 240 v was allowed a little tolerance so our 12.5 amps could be plus or minus that.
Most heaters etc were purely resistive therefore that that 12.5 amps still pretty much holds good.
Although our voltage has "nominally changed to 230v to align with Europe etc it has not really changed so 12.5 is the figure we should be looking at.
Ok there are a few items that actually change the current to accomodate the voltage variation to compensate butin the grand scale of things not that many, so in essence we are better to stick to the old figures to get an appreciation of things.
Gone are the days when common fan heaters etc were 3KW anyway and 2KW is the "New normal".
We sensibly tend to stick to 10A max or 2KW max to anything connected to any decent make of plug for any length of time and to bear in mind the safety sleeve on modern plugs must affect heat dissipation compared to the older plugs.
Again sensibly we tend to have any appliance limited to the notational 2KW if its not to be wired to its own circuit rather than a ring or a radial circuit and best limited to one per circuit.
I my youth it was not totally unknown to see 3 or more 3KW heaters on one bog standard plug in circuit - oh dear!
The bad old days when electricity was dangerous
My father was an old school electrician we unplugged everything at night
Yes indeed we were all taught that electricity is dangerous, hence things not needed were unplugged, especially at night or away from home - perhaps this might have offered some mitigation and modifying a little to some of the very questionable ideas that some ordinary folks with little or no basic idea did on a regular basis - today it would make your hair curl, but there were no piles of dead bodies on every street corner like you might imagine, today we still get people doing stupid things plus we have lots more protection, unfortunately some folks rely on that protection in preference to being more sensible so the outcome is - increase stupidity minus add protection equals decrease stupidity and reduce protection.
A bit like folks driving like absolute maniacs because cars have more protection .
You cant win!
And was this "edict" based on anything other than ignorance or superstition?
I don't know how thick the sleeving is (has anybody here ever cut it away to find out?), but the starting position is L & N pins with a csa of about 25mm².
Whatever the cause(s) of overheating plugs and sockets there may be, I very much doubt it's insufficient current carrying capacity of the pins.
How many appliances can you buy which are 3kW at 230V?
And at a lower voltage it is less than that, and at a higher voltage it is more, because apart from plug-in countertop induction hobs and microwave ovens the devices are resistive.
And it still is.
They still are, and it still does if the voltage is 240. But then it only ever held good if the voltage was 240.
No, we should be looking at the figure which the manufacturer quotes for the appliance at 230V.
If we consider this nominal 3kW-at-240V appliance, it "used to be" an actual load of 2660 - 3360W, drawing 11.8 - 13.2A.
Now it is an actual load of 2430 - 3334W, drawing 11.3 - 13.2A.
I really, really, do not see what the issue is.
And if we consider this hypothetical 3kW SMPSU type device, it "used to" draw 11.8 -13.3A. Now it draws 11.9 - 13.9A.
Yesterday at 11:42 PM
Morqthana - I was Quoting someone else`s statement,
Trying to point out that 3KW at 240v was 12.5 amps therefore just under the 13 amp of standard UK plugs (of course we still had a tolerance allowed on voltage actually present in installations).
In answer to your "How many appliances can you buy which are 3KW at 230V?"
My answer (guessing it) is probably around none I think.
I suspect that most manufacturers still quote the old 240 volt figures for wattages of their products where they think they can get away with it as their headline statement, perhaps they should be taken to task and if quoting only one figure or headlining one figure it should be at the official "European" 230 volt equation?
I don`t have any objection if they additionally print a slightly smaller or less noticeable statement alongside about say they explain at the 240v figure would therefore be more watts for their products .
The problem is some items the current increases with increased voltage and with others it drops. Anything with a switched mode power supply the current is likely to drop as the voltage raises.
So with a cooker, with an induction hob, which way will current go with voltage?
Well Eric,
with the purely resistive elements on the majority of things it would be a simple ohms law thing dependant on volts and ohms present altering the watts as you`ve said but with a few of the more "new fangled stuff" incorporating some electronics it would alter the current used to keep the wattage constant.
