Kitchen wiring
Appreciate the responses.
Quick recap:
Very small kitchen, 2 double sockets is enough
Extractor hood on lighting circuit. Never seen that, good idea if allowed
Cooker isolator under worktop in adjacent cupboard, I read its allowed so long as its in the upper section above the cupboard's contents.
Hob and oven, share connector unit, got it
Fridge/freezer plug is off to the side. Appreciate the consideration.
I think that's it?
So no DW/WM/TD?
Until I read that I was going to suggest
It's allowed anywhere.
No requirement to even have a local isolator for it. Could be switched off at the consumer unit in the event of that needing to be done.
True but I much prefer the 2m from the cooking appliances approach and not too difficult to find in haste if required .
If we takes the Regs as the bottom line of what we musr do then anything we consider better than the regs state to comply must usually be desireable surely?
To move a kitchen, needs planning permission. At least that's what the LABC told me.
As to RCD or RCBO in my kitchen cooker on its own RCBO and all but fridge and freezers on a ring final RCBO, with the rest of that side of the house.
The fridges and freezers run from two double RCD sockets, supplied with SWA from an inverter so an EPS supply.
To make sweeping statements about RCD or RCBO is assuming they are all housed in the consumer unit, this does need to be the case, I think it is good to power the fridge or freezer from a supply unlikely to fail, but up to you as to what lengths you go to.
pete01....you clearly haven't got a toaster like mine then! I clean the inside, check for burnt bits, clear the bottom tray every day etc. but it will trip the kitchen circuit every few months without fail!
No my toaster seems ok.
Haven't ever been, around here at at least. Always worked out of the same office but classed as a different department, thus different applications
OK, my experience is slightly different, the first couple of planning applications I saw the planning officer to ask advice, handed in the application, when approved the same guy came out for some of the inspections. I assumed that was normal.
Perhaps they have some common sense in your area. Although in fairness to them they did used cover for each other if one was off sick or on holiday and you had an urgent need. We only used to have one of each :giggle:
