Plug in solar
Then get it hard wired and professionally installed. This was always an option before now anyway.
Yes exactly, the battery pack method has been available for years, I had considered DIY solar, but to fit on the roof, forget it. And on the wall, simply not big enough to be worthwhile.
To my mind it needs to be large enough to work as a package, off-peak, battery and solar.
The plug and play solar is OK as an addition to existing, but as a stand alone, with no battery, and 800 watt limit, and no export, it is next to useless. At £300 for the kit, maybe, but at £700, simply not worth it. A battery pack would give a far better return.
Then just avoid it if it isn't for you. If someone wants one with a battery then they should get it professionally installed. The regs will develop and batteries will, I think, be introduced to the plug in kit in time. But for now, they aren't.
Certainly some folk do that, you can trick some of the people some of the time and that amounts to loadsa money so the ad industry has loadsa money.
If you look back at some things sold as the best 20,30,40 or more years ago and that every so often the made a new improved one then that must prove that a lot of the previos ones were absolute carp so surely we should all get some refunds? ;)
1787771200540.pngI look at my 6 kW solar panel and my use, and without a battery or export payment the gains would be low.
So ok as they haven’t updated G98 (if they ever do) so we are limited legally to only 800 watts ( not worth it ) even though they obviously want us to be able to have more due to the wording .
As I have two sides to my garage roof can I have two sets of 800 watt panels and put them on timers so when sun goes to my south westerly side one set turns off and the otherset turns on.
Would that be breaking the rules
Ok I’m not gonna do but you know someone is gonna think about it.
You and yours live in the front of your house and your cousin lives in the back of the house - is that "two households"?
The usual suspects might contrive either viewpoint from that one LOL
Not required, as one inverter can have two inputs. And as long as it is unplugged once every 28 days, then not installed, as far as G98 goes. You are allowed 28 days to notify, so unplugging and plugging back in resets the timer.
In real terms unless you have a smart meter, there is very little possibility of the DNO knowing you have plug in solar. Battery pack solar still has solar panels, and there has never been anything to stop it. So existence of solar panels tells them nothing.
Basic five types of meter:-
1) With export it runs backwards.
2) With export it adds it to the import.
3) With export it flashes a red LED to show fault, but does not record what is exported.
4) It has two registers and cycles between import and export.
5) It is assigned two MPAN numbers records both import and export and transmits the information to suppliers. The payment for export does not need to come from the same supplier as the import.
6) Two completely independent meters one for import and one for export, both of the type shown in 3).
The two-meter method was stopped late 2022 or early 2023, unless you already have them fitted, only official way to be paid for export is 5) the so-called "Smart" meter. But those with 1) type will also get paid until the supplier realises your bill is far too small.
With 2 x 1000 watt panels into an 800 watt inverter, one should get 800 watt for most of the day, when not raining, it would be like me having a 2.4 kW inverter, so I looked at yesterday 1787820284187.pngthe black line is where the inverter would be at maxium, so yesterday a 2.4 kW inverter would not have lost me that much solar, and at the moment my 6 kW array is producing 109 watts (09:48) which is why I have batteries charged with off-peak.
( not worth it )
That is also what I would say, only those who already have solar, would likely gain from the grossly overpriced kits.
