Fused spur
5 Sep 2026
In our old house in the bedroom there are 2 single sockets either side of the bed that are basically an extension lead running under the floor popping up next to the only socket in the room with the extension lead terminating in a 3pin plug.
I wish to replace this with a proper fused spur to the bedside sockets.
Are there any double sockets with one side being a 3pin and a fused switch other than the 45amp cooker ones, or do I have to install 2 single boxes?
The existing socket is a ring btw
You could fit the FCU next to the exiting socket then feed the bedside sockets from that.
Dig out the existing single box and fit one of these
Fit a 13amp FCU on one side and feed the socket (and the add-ons) from ther load side of the FCU.
Simples
If he can get under the floor to replace the cable, why not extend the circuit?
Thanks everyone. I did consider extending the ring but, tbh the floorboards are very old and lifting them without damage isn't worthwhile. I was under the impression that any spur off the ring should be fused.
Why don't youu ever just answer instead of picking at other people's suggestions?
Why don't you ever stop criticising me for not giving the answers you think I should, or for asking questions you think I should not?
I wondered if extending the circuit rather than using a spur was an option, hence
Is access to the cables under the floor easy?
Just use 4mm, no fuse needed then.
To do that, he'd have to lift floor boards and install a new cable. If he can do that, he can also extend the circuit rather than using a spur.
Hence this:
You just don't want to see anything posted which runs contrary to anything you've posted, do you.
