Burnt tails
31 Mar 2006
Yorkshire
Guys
I have a photograph of some burnt tails. I'de be interested in peoples opinions as to what may have caused this.
I cant load the photograph up. Can anyone advise how you do this?
D
No. Creating accounts can put people off posting pics.
In my opinion, uploading to www.tinypic.com is easier, quicker, and no membership required.
For posting the pic to the forum.....hang on, I will see if I can link to a thread I worte about this on another forum, but which will work equally well here...
Without seeing the photos . . .
Undersized tails on large supply
Oversized mainfuse c/w long slow overload situation
Loose connections in meter, cutout, fusebox, isolator
Overheating connections
The list goes on, but the above are the more obvious / common.
assuming it is a domestic and the tails are not insanely undersized I would imagine bad connecions are the most likley cause.
Yep. loose connection on the right hand neutral tail by the looks of things.
A good time to ditch the unnecessary henley block :D
Yup, a loose connection on the RH side. Heat as travelled up the block and also damaged the LH tail.
I am a big believer in the good old tails from meter directly to CU - No henley blocks, no isolators, nought! Loose links in the chain.....more to worong.
