I am having a new kitchen fitted and replacing the electric oven/gas hob with an all electric Range cooker with a quoted max rating of 14.8kw. This will be on the opposite side of the kitchen to the previous oven. I was surprised to learn that my electrician plans to use the existing 6mm cable from consumer unit to isolator switch (around 18 Feet)and run a 6mm cable from it (about 20 feet) to the new cooker. The manufacturer gives a max rating of 7.43kw to the hob leaving 7.37kw for the two ovens. Our kettle is rated at 2.45 - 3kw. My view is that it will be too easy to overload this circuit on a big cooking day (xmas?) by switching on both ovens (30A) boiling a kettle at the isolator socket (12A) and frying an egg on the 2.02kw plate (8.4A). Thats a total of 50.4A. What would the voltage drop be over this installation? I am a complete novice but feel I need a 10mm cable to this cooker. I have yet to have this out with him as a lot of the prelim wiring has been done and the kitchen is fitted starting next week. I request comments from qualified electricians please, to assist in my argument. I did ring the manufacturers and they said that using diversity 6mm "should be alright" but then said they were not electricians!
Please reply ASAP before it may be too late.
