Hi all,
I had a bit of a mishap yesterday - I managed to nick a microbore central heating pipe with a chisel. That was quite a fountain...
Anyway, of course it's 5pm, no shops open, so I had to put in an "emergency patch" - reducer into a braided "flexi" hose, attached to a 15mm capped end.
That in itself was a challenge, involving cutting and removing part of a floorboard and cutting the pipe back to a section that was straight and still round enough for the reducer and olive to fit over (and working in an extremely tight space...)
Currently the system is full again (drained it down but refilled to check for leaks) but the pump is isolated from the electricity, because I'm not sure if a flexi is up to the job.
Can flexis be used in a central heating system, or do the pressures involved require copper tubing throughout?
I only ask because to replace the flexi with copper is going to be a major headache, but having said that if it needs to be done, it needs to be done.
