Doors
1 Dec 2006
Cumbria
I am intending to fit a built in wardrobe in a small room, because of the size restrictions I was hoping to fit a roller door( like you see on some kitchen cupboards & filing cabinets) but have not been able to find a supplier of the required size( Screwfix have them but only 500mm wide). Can anyone help or suggest other solution for space saving door?Thanks.
Is the cup'd in the corner of the room, if so fit standard doors as no space is saved with roller door.
It is a small bedroom where the bed would prevent a conventional door from opening into the room
Not offended at all Bespoke, but nothing set in stone as yet as far as dimensions are concerned, but there will be no space worth mentioning in front of it which is why I would like some sort of roller door. I was really hoping someone would be able to name a manufacturer/supplier of different size doors. I did think about a roller blind, but would prefer something more robust. The only other thing that I could think of was an inward opening multi-fold door, but it seemed to make it more complicated.
twice as long from the middle to the end.....a long piece or a short piece of string that is :wink:
search for "Tambour door"
they are a bit noisy
