Make sure you..
11 Jan 2004
attach the MCB securely to the busbar...
had he forgotten to wind the screw to the "fullly open" positon before putting it onto the busbar?
Busbar is also back-to-front.
The end with the holes is intended to be at the 'low load' end.
I would hazard that the busbar was the wrong side of the 'vice type' terminal.
Shower is on the RCD side.
Good old MEM Memshield 2000.
I have seen busbars mounted on plastic pillars in some makes of CU - GE spring to mind.
