Back boiler - advice
3 Apr 2008
Hampshire
Can anyone help???
We buying a older style property that has a back boiler behind the fire in the lounge.
The fire is hideous... and im not sure how long i can live with it!!???
Does anyone know how much (roughly?) it would cost to fit a new boiler? Its a three bed house?
And what type of boiler i should go for??
Thanks :?
what type of boiler (bearing in mind it must be condensing)
what type of boiler do you want to go for :?:
and bear in mind whichever way you jump it aint gonna be cheap
get it done right and get it done once :wink:
you cant change one without the other and the only way forward is to sacrifice the boiler and fire and opt for a new condensing combi boiler
using the existing pipework and radiators which at the very least should be flushed with cleanser before fitting a new boiler should set you back between 1 and 2.5k depending on make model of boiler and location in property
tosh
you can have a new condensing boiler and tbf i would advise a new high recovery cylinder
you are not tied to a combi unless that is what you want
:idea:
oh ok - i think i get it now???
So i could probably use the old pipes and rads etc.. but they need flushing and it depends on what boiler i go for for the price, right>
All boilers now are condensing boilers.
Amptec :!:
ohh sneaky
