dodgy plumber?
3 Apr 2008
West Midlands
i have or tried to have a shower pod fitted. this is now up to its 11th day. the shower pod is fixed together but doesn't work. my plumber had caused 4 leaks through into my kitchen which the ceiling is now ruined. i have bought 3 pumps of all of these he says aren't working. do you think it is the way in which he has layed the pipes that would cause the pump not to work, surely i cant be unlucky enough to buy 3 pumps that dont work? is there some where that i can have it checked out? please help cos i am at the end of my tether
He showed me this card !!!?!?!
You need to check the pipe layout make sure there are no high points, these high points collect air
What exactly is the toy you had fitted?
If its made in China then its probably got a lot to do with the kit!
Where did you buy it?
Can you post pics?
How is your hot water produced? Combi, conventional cylinder, unvented cylinder, magic! etc
You guys have been absolutely great over the years helping me on numerous occasions overcome plumbing problems. I read this post with some scepticism yesterday but the poor woman's despair was brought home to me very early this morning.
Yes her husband, a friend of mine from the pub, phoned in desperation and asked me to go round. I was met with water pouring through the ceiling and when he led me upstairs the sight that met me was unbelievable. Unsupportd pipework, 7 inch joists, notched down to 21/2 inches, electric wires trapped by the new pipes etc.
However the worst was the pipework that had been altered. Original copper pipes cut, teed off and new piping in plastic speedfit. Ok this should be fine but not one of the joints, there are over twenty, had been locked off by twisting clockwise. Two of the joints to copper pipes were "spirting" water prodigiously. I pushed them together locked them off along with all the others and leaks through ceiling stopped.
Now to the shower not working. This is one of these "tardis" cabinets with jets coming from everywhere! I would imagine any plumber worth his salt would have fitted a flange, Essex preferably, but at least warrix/surrey. No the hot was taken from the main hot water system pipe, not immediately as it leaves the cylinder but way down by the floor!
Plumber had sent the woman out three times to buy new pumps, the first one failing to work after two showers! He was testing the shower by plugging into 13amp plug socket although obviously the pump leads were just tails and had to be plugged. You have probably guessed it two days work trying to get this shower to work at all was due to the original shower being fitted with a plug taken off a table lamp (3amps) which had blowned after the two showers taken with the first pump. Changed the fuse to 5 amp (I know this has to be run out of fused outlet etc, but just wanted to see if shower worked) pump sprang into life!!! The plumber had already contacted Showerforce, who are sending engineer out Monday.
You guys do not deserve to have such people representing your profession, this guy was 40+ and had been at it a few years i understand. He has been told to sling his hook, quite rightly and he says he will present his bill for work done next week. Now he has done work, for which he will be paid, but how would you reflect the mistakes that have caused so much extra work which has and will need to be done. Oh yes changing radiator to towel warmer he wrecked the CH and another plumber had to come out for 11/2 hours last night to get it working, he couldn't.
Sorry about the diatribe but I was incensed that such a man could cause so much hassle and ruin your well earned respect, certainly as far as I am concerned. Rant over!
But this is the problem we face! Its the customers fault as they look for the lowest price and they are prepared to let anyone into their homes without knowing who they are or their capabilities.
In most cases they allow a smart talking charlitan to carry out work which they are totally incompetent to do.
If they really knew who he is then they should tot up the cost of damage caused and putting right the bad work and counterclaim from him.
They never do though.
Tony
Well it certainly sounds like he done more damage than the cost of the job, I would ask for the name of his insurance Company and get that sorted long before he got any money.
Tony
but your a boler engineer surley not a lowly plumber :?:
Yes, I am a boiler engineer!
But there is nothing "lowly" about a plumber!
A properly experienced plumber is an expert in the area of work in which he specialises!
I am sure that the same problem arises in any area of work in the home as with plumbing. The only difference is that electricity does not jump out of the wires and damage ceilings or carpets so bad electrical work is rarely noticed.
The only area of work where faults are more obvious than plumbing must be roofing!!!
Tony
