N
namsag
Baggsie the name The Teflon kid and fighting out of the blue corner.
Erm, our impression is that they make things up as they go along. Not disrespecting them , there are often gaps in the standards and the BG books do their best to make sense of what was intended.Nope its fom a BG training manual that takes everything from the standards.
Then you're a DIY DORK. The thickness is yours. The two tapes are NOT the same.Seems as though I can keep using normal ptfe for my diy gas exploits as the two are the same according to Onetaps link.
Apart from the thickness that is.
Happy Days......![]()
BOSS GT PTFE tape. "This tape satisfies demands of BGC IM/16 and is suitable for town gas, natural gas and LPG."
http://www.bssuk.co.uk/bsscomm/uploads/productinfo/BOSS_permanite_GT_PTFE_tape.pdf
BOSS PTFE tape. "Used by plumbers and heating engineers to provide a watertight seal on threaded joints."
http://www.bssuk.co.uk/bsscomm/uploads/productinfo/BOSS_ptfe_tape.pdf
They are the same material, i.e., both "100% pure, virgin PTFE and containing less than 0.1% wt residual lubricant".
The only difference is the thickness, 0.20 and 0.075mm.
Actually the thickness is not the only difference. The gas tape is twice as dense. There's your answer.
As a matter of interest how did you measure the density?
Tony
DIY DORKS only, click HERE
Then you are an even bigger dork.![]()
Low porosity ?.
And I thought your link might have explained namsags stance on the natural gas reacting with the thinner ptfe.
There is no reaction. Its a made up load of baloney.
It speaks volumes when he is unable to provide any information relating to the chemical make up of the two tapes to support his argument.
As for the low porosity thats overcome by lapping more tape around the threads.
If it has low porosity then how come I have used the stuff on industrial refrigeration systems pressurised to 30 bar in some cases and NO leaks ?. EVER !.
Onetap stop harping on about gas exploding on contact with ptfe we only have your word the guy said that.
Simple its got nothing to do with the thickness of tape . I use one wrap gas tape and you can get one wrap water tape it both the same thickness but the water tape REPEAT CANNOT BE USED ON GAS . people far cleverer than you and me have made this decision for an obvious reason .Live with it.
IF the answer is density
Less dense means more room between the molecules which mean whatever molecules that are in the gas that can react as they have more room to get in and react.
More dense means tighter molecular structure and whatever molecules within the gas cannont fit into this tighter structure . Bit like how osmosis works
Yes, but you have to do an EFLI test afterwards.Can i use PVC electrician's tape?
Quality.I've had a really good look with a magnifying glass and it doesn't seem to be porus. Obviously i wouldn't use blue or red as this may be confused with the hot and cold water supply.
