I am having trouble getting the boiler / pump to remain on long enough to deliver hot water to all of the radiators.
The pump switches off when the boiler switches off (I might be wrong, but I thought that the pump remained on for a while after boiler switched off to continue circulating the hot water??)
I have removed the vent plug from the Grundfos pump & spun the shaft (which was free anyway) The pump body is very hot to touch (is that normal?)
I left the vent plug out & switched power on to the system. The pump ran for a second & then stopped. Should it have continued to run?
The boiler does not stay on very long before switching off & then on again after a few minutes. Occasionally the overheat light comes on.
Am I looking at a boiler problem or a pump problem?
Any help would be appreciated
