I’m currently fitting an Abacus WC wall hung frame. Not experienced with fitting toilets so some advice would be helpful. The toilet frame comes with a 110mm elbow waste connector, I was assuming it would fit into the existing white pipe part but it is loose. Is there any adapter or should the white bit be removed and I use an extension to the supplied 110mm pipe into whatever is below the current white connector. Thanks I’m advance!
