I need to lift a section of floorboards that have a dividing wall on top, so need to cut along the joists. No problem I thought, I can finally use that Bosch mulitool that's been sitting in its box for a couple of years. Charged it up, fitted the blade & away I went - not! The two supplied blades look like they'd struggle cutting cheese judging by the zero impact on the boards. And that's with starting the cut with an old, blunt floorboard handsaw that I knackered cutting laminate 10 years ago.
So before I go & potentially waste another £15 on the Bosch 65mm hardwood blade, are they actually any good for this job? As usual I can easily find YouTube videos of guys making it look like a doddle, so do I just need the right blade?
