Late 80s, very early 90s, I would say.
What I always remember was a course I went on about 2005, and the instructor explained that the way it's going to remain apparent whether an installation was likely to have been installed after the new regulations came into force, and therefore had probably needed to be notified through BC was the obvious change of colour.... harmonisation of the the cable colours was nothing to do with Part Pee.
Whilst what you are implying would obviously make some sense, I suspect that it really was essentially a pure coincidence. The change to harmonised colours for non-flexible cables was very long in the planning, and the date of change was very probably decided long before anyone had even dreamed about a 'Part P' - don't forget that those harmonised colours had been introduced for flexible cables very many years (decades) earlierWhat I always remember was a course I went on about 2005, and the instructor explained that the way it's going to remain apparent whether an installation was likely to have been installed after the new regulations came into force, and therefore had probably needed to be notified through BC was the obvious change of colour. .... You may think it was just a coincidence that the two changes in the electrical industry came about around the same time, some would disagree.
Yes that is viable a questionI wonder if this installation is earlier than the fuseboard
How old is the property?
Indeed so - and I have a feeling that it may only have been necessary to be able to argue that the work had been 'designed' prior to the advent of Part P to be 'exempt' from it, even if the work were actually done appreciably later.You might look at paperwork and see an outstanding number of installations that were "officially done" before Part P and notice a great big spike in statistics, far greater than random chance might suggest.
I don't really think that anyone could criticise you for making such a suggestion, even if you didIt is not for me to suggest that some juggling around with dates was used to circumvent some aspects of Part P.
'Officially', it obviously wasn't. The question being debated is that of whether the interesting 'co-incidence of implementation dates' may have been in some ways 'manipulated'.It was nothing to do with Part P.
Exactly, but some people have tried to include it and some people have suggested they occurred at the same time thereby .It was nothing to do with Part P.
Probably the same inspector who won't sign off SUNRAY's work until he does something that isn't required.Exactly, but some people have tried to include it and some people have suggested they occurred at the same time thereby .
Indeed our local building inspector said he would use the colours of evidence of Part P or not.
I was still installing rewirable Wylex boards well into the 90's. We moved into the house I'm in now in lat 1994 and it was several years later I changed one of theseIt has to be 80s, well I think so anyway...
70s would be rewireable
90s would be split load
Ish...
If you're referring to the crazy earth bonding situation it was far from only me affected.Probably the same inspector who won't sign off SUNRAY's work until he does something that isn't required.
