I’m installing a wall-hung toilet frame and need to build a boxed-out stud wall for it. The toilet will sit under a bathroom window, so the new stud wall will only be about 125 cm high and will stick out from the existing wall around 20–25 cm.
Because of the window, the studs can’t run all the way up to the ceiling. The base of the frame will be solid because it can be fixed directly into the floor joists, but I’m unsure about how to secure the top of the stud wall so it has no movement.
Right now the studs would come up from the floor but have nothing to tie into at the top. I was thinking of fixing a horizontal timber to the wall just under the window so the tops of the studs can screw up into it but I’m not sure how best to secure that timber to the wall or how to stop the whole thing from moving side-to-side.
What’s the best way to stabilise the top of a half-height stud wall like this? and what sort of size and type timber should I use for this please?
Many thanks
Many thanks
