Forum Update
Previously I would select the alerts icon when it's showing as having some then be able to right click on the thread it is alerting me to and open it in a new page.
Now I cannot?
Windows 10/Google Chrome.
Is there a reason why when I now add hyperlinks, they are inserted at the beginning of a reply? My workaround is to return to a new paragraph and then backspace it up! :evil:
Same here. I add the hyperlink and then type my post, jumping the hyperlink if I have to.
I do not doubt what you say. I only visit this site via my laptop (windows 10/ chrome). I have no complaints.
Forum is broken on Firefox 114.0.2 (64 bit) on Ubuntu 20.04 LTS
Can't close the cookie options pane, site behind is greyed out. I'v e cleared cache and cookies. Clicking either cookie pane option option give
various error messages:
Google Publisher Tags is being shimmed by Firefox. See https://bugzilla.mozilla.org/show_bug.cgi?id=1713685 for details. sandbox eval code:1:9
Ignoring unsupported entryTypes: largest-contentful-paint. electrics:42:160
Layout was forced before the page was fully loaded. If stylesheets are not yet loaded this may cause a flash of unstyled content. fads.js:2:290
Amazon Transparent Ad Marketplace is being shimmed by Firefox. See https://bugzilla.mozilla.org/show_bug.cgi?id=1713698 for details. sandbox eval code:1:9
Some cookies are misusing the recommended “SameSite“ attribute 7
Loading failed for the <script> with source “https://www.googletagmanager.com/gtag/js?id=UA-2580562-1”. electrics:254:81
Loading failed for the <script> with source “https://ezodn.com/detroitchicago/consentsettings.js?cb=2”. electrics:381:94
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://bshr.ezodn.com/?did=40317&bf=30000&dc=1254144. (Reason: CORS request did not succeed). Status code: (null).
Loading failed for the <script> with source “https://ads.pubmatic.com/AdServer/js/pwt/162833/9311/pwt.js”. electrics:1:1
Uncaught TypeError: window.PWT.requestBids is not a function
openwrapRequestAdUnits https://www.diynot.com/diy/forums/electrics/:4722
process https://www.diynot.com/diy/forums/electrics/:3
m https://www.diynot.com/diy/forums/electrics/:3
u https://www.diynot.com/diy/forums/electrics/:3
onerror https://www.diynot.com/diy/forums/electrics/:3
electrics:4722:266
Loading failed for the <script> with source “https://g.ezodn.com/cmp/v2/v.js?v=4”. electrics:4698:56
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://ezodn.com/cmp/gvl.json?v=3&lang=en. (Reason: CORS request did not succeed). Status code: (null).
Loading failed for the <script> with source “https://get.s-onetag.com/48e9aff7-e1fb-417c-a320-ed101cdab11f/tag.min.js”. electrics:1:1
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://bshr.ezodn.com/?did=40317&bf=4600&dc=1254144. (Reason: CORS request did not succeed). Status code: (null).
Loading failed for the <script> with source “https://go.ezodn.com/hb/dall.js?cb=195-0-57”. electrics:1:1
The resource at “https://www.diynot.com/diy/styles/fonts/fa/fa-brands-400-min.woff2?_v=5.15.3.1652997379” preloaded with link preload was not used within a few seconds. Make sure all attributes of the preload tag are set correctly. electrics
The resource at “https://www.diynot.com/porpoiseant/fads.js?gcb=195-0&cb=13” preloaded with link preload was not used within a few seconds. Make sure all attributes of the preload tag are set correctly. electrics
Uncaught TypeError: this.tcModel is undefined
handleAcceptAllClick https://the.gatekeeperconsent.com/v2/cmp.js?v=111:1
handleAcceptAllClick https://www.diynot.com/diy/forums/electrics/:354
onclick https://www.diynot.com/diy/forums/electrics/:1
cmp.js:1:293501
electrics:4722:266
cmp.js:1:293501
Same issue, turned out to be my DNS service, NextDNS. It's privacy centric, so something on the forum cookie page is a bit spy-ie
How do put in a post
I want to post a electric query (how)
Go to the "Forums" page
Run your eye down the sections until you reach "Electrics UK" and select it.
Look for the field "thread title" and type in a title that describes your subject
Look further down and type your question.
Only temporarily, we had to update the forum software and the styles were affected unexpectedly.
It'll will return hopefully by the end of the day.
Sorry for any inconvenience.
Has this gone? My laptop has gone back to a narrow view and I can't find the above now.
What happen if you press Ctrl 0?
Edit: sorry only just noticed that you had a reply. My laptop is the same as ever? I am using chrome.
