Constant trickle fans -Fan isolators or fused spur?
5 Jan 2009
Hi all
Cracking on with rewire on one of my properties and done x2 rings and ripped out all the old wiring etc.
Looking to fit x2 constant trickle fans.
One in bathroom and one in kitchen.
The kitchen one was fed from a switched fused spur (4" hole already there).
The bathroom one upstairs would benefit from a ceiling fan/ducting/vent tile tbh.
I like to fit Envirovent constant trickle fans with humidity sensor and boost function.
I also don't want them turned off 'to save electric/jeep bathroom/kitchen warm'.
Can I just use a non switched fused spur without as means of isolation?
Cheers
I don't think they will bother to remove a fuse tbh.
The Envirovent fans are silent on when on constantly/trickle.
They will only be aware of them when boost is activated.
The reason is I have had this before with fan isolators being fitted and mould/no air flow in bathrooms and found fan isolators switched off.
Also is there an option to do this via the ceiling/inline fan with constant trickle/humidity boost?
Cheers
One reason I put the fan isolator up near the ceiling, if someone really needs to get it switched they can, with a stick, if need be but not low enough to encourage a habit of switching on and off and possibly forgetting.
One of my other properties has them fitted above the doorway/entrance to bathroom and kitchen.
Tenant keeps turning them off as she reckons it makes the rooms cold.
Starting to get black mould in areas now and have never had problems before.
Cheers
What is that type of seal?
Plus where could I mount them out of reach??
The seal, need be nothing more complex than sticky back paper, with your signature upon it. So long as it rips easily, with any attempt to remove it.
Out of reach - up at the ceiling, in a cupboard, use imagination.
Very sticky (not 'low tack' / 'easy peel') masking tape works well, since it's almost impossible to get it off without tearing or, at least, creating obvious damage.
Yes the objective is to deter/reduce chance and give a greater chance of visual alert rather than prevent - a perceived possible success rate of around 90% or so is better than nothing at all.
Now and again someone might remark - I want my electrics to be "idiot proof", my first thought would be " I do not really want an idiot to be using electrics"
An alternative, but more expensive, would be a key-switch - which needs an actual key to turn them on/off, or cheaper - a fish key switch, as used as an emergency light, test switch.
a 3 pole fan isolator "fish key" switch ("Grid switch" type) is about £7 inc VAT from Screwfix etc,
