Light switch spur
6 Mar 2011
Glasgow
I want to install a light in a cupboard I'm building. My plan was to spur off the existing socket to a 13A fused light switch. I say was, because I've just discovered that the socket is itself a spur. I've always thought that you can't spur off a spur, however I have read online that it's ok for a light switch providing the socket is fused. So is it still possible to do what I want with some further modifications, or am I screwed? If it's possible then I'd appreciate full instructions on what I need to do. Specifically with the socket and any fuse changes. Also, can I use 2.5mm T&E from the switch to the light fitting, or do I have to drop to 1.5mm or 1mm?
Is the socket spurred directly from the ring unfused or is there a fused connection unit (spur) before the socket
I don't think I have any 1.5mm or 1mm T&E, so should I stick with the 13A fuse if using the 2.5mm into the light fitting?
No, swap the 13amp fuse for a 5amp. 13amp in the FCU, which feeds your socket+ light, then a 5amp in the FCU to protect the light part of your circuit.
If you put an fcu before the socket you dont really need a second fcu just a light switch as the original 13 amp fuse will protect the lighting cable aswell. (By a long way as you plan to use 2.5mm)
Basically, with a Ring Final Circuit you can run a Radial Leg (Called a Spur) from it either fused down or not - the max load on that spur can be one twin or one single socket (or one Fused Connection Unit - switched or not switched as required) .
You can actually do the same with a correctly sized Radial Circuit too (say 4.0 or 6.0 perhaps),
A Ring Final Circuit is usually 2.5 T & E and a spur from the ring is usually 2.5 to run one twin or one single socket or one Fused Connection Unit (switched or unswitched) , that can take a 13A max fuse. On that fused side of that 13A fuse you can run as many items as you want and you might decide to use another FCU to run a lighting circuit on say a 3 or 5 amp fuse for instance , any spur from the ring can do the same, you can atually spur from a radial final circuit but that`s a different topic.
Think of Spurs in Electrics as you might do to think of Spurs on train lines - a branch off the main line.
Some people wrongly call an FCU (switched or unswitched) a "Spur" it is not a spur, in essence the cable itself is the spur whether from a ring or a radial final circuit.
The ceiling rose, lamp holder, and flex, will likely only be rated for 6amps, so I would suggest a 5amp fuse to protect those.
Thanks. This is a really clear and helpful description.
