I want to install a light in a cupboard I'm building. My plan was to spur off the existing socket to a 13A fused light switch. I say was, because I've just discovered that the socket is itself a spur. I've always thought that you can't spur off a spur, however I have read online that it's ok for a light switch providing the socket is fused. So is it still possible to do what I want with some further modifications, or am I screwed? If it's possible then I'd appreciate full instructions on what I need to do. Specifically with the socket and any fuse changes. Also, can I use 2.5mm T&E from the switch to the light fitting, or do I have to drop to 1.5mm or 1mm?
