1 Gang 20mm Spacer
11 Jan 2004
Am looking for one of these to extend the depth of a box.
White, with square corners.
I can find plenty of spacers 10mm, rounded corners.
Does anyone know where to find one?
Cheers.
No, doesn't exist, all plastic fittings have rounded corners. I thought you were a spark?
Never seen a square edge spacer frame. Only round edge. MK do a 20mm but ofc it's round edge.
Does it need to be exactly 20mm or could you butcher a 16mm/25mm standard PVC patress and just remove all of the back and the brass lugs?
Sounds sensible to be tbh, the only objection I can see is those boxes tend to be quite brittle so cutting a 20mm chunk off the front successfully might be a challenge.
Look up antiference wall spacer.
I think that may help, perhaps you can double them up.
Thanks, guys!
Igg, Yeah, at a pinch I could jig the back off a PVC box, but my jig is no more and I'm not relishing doing it with hand tools!
SW: :) Will look at Antiference, cheers.
According to some reviews, the Antiference spacer is grey, which will look a bit daft.
I can only find the 2 gang on their website, one square cornered, one round.
But I can't see a 1G spacer.
