- Joined
- 9 Aug 2015
- Messages
- 3
- Reaction score
- 0
- Country
What fittng is the safe to have light on continously for 12 hours
To be honest, although I may just have 'missed' them, I don't recall ever having seen a light fitting whose manufacturer says is not suitable for continuous operation (up to the maximum stated lamp/bulb size). There are many situations in which lights are left on continuously and, if a fitting were not suitable for such use, one would expect/hope that manufacturer would say so.What fittng is the safe to have light on continously for 12 hours
Indeed, but that's a general truth - and, if they are going to get hot, that usually happens pretty quickly, after which equilibrium is achieved and no further rise in temperature occurs. The 12 hours of operation the OP refers to is not significantly more than 'normal usage' - many lights in houses will be on for 8 hours or more during the winter, so if one would be happy with a particular light fitting for that sort of 'general usage', it ought to be equally OK for 12 hours.Some fittings get quite hot even when the lamp wattage is at or less than the rated maximum wattage.
LOADS these days state not for continual use. I'm for ever swapping out cheap 2D fittings which have failed, and many have a sticker on the gear tray clearly stating not for continual use. Obviously missed by the installer.To be honest, although I may just have 'missed' them, I don't recall ever having seen a light fitting whose manufacturer says is not suitable for continuous operation (up to the maximum stated lamp/bulb size). There are many situations in which lights are left on continuously and, if a fitting were not suitable for such use, one would expect/hope that manufacturer would say so.What fittng is the safe to have light on continously for 12 hours
Kind Regards, John
I was obviously right in saying that I might have missed them!LOADS these days state not for continual use. I'm for ever swapping out cheap 2D fittings which have failed, and many have a sticker on the gear tray clearly stating not for continual use. Obviously missed by the installer.
Any examples? So everyone can avoid buying them?LOADS these days state not for continual use. I'm for ever swapping out cheap 2D fittings which have failed, and many have a sticker on the gear tray clearly stating not for continual use. Obviously missed by the installer.
Indeed, I'd like to know the answerto that, too! I's also like to know the answer to my question as to what they mean by 'not suitable for continuous use', given that, as I've said, many a kitchen or living room light will be on continuously for 8 hours or more per day in winter (mine certainly are!)!Any examples? So everyone can avoid buying them?LOADS these days state not for continual use. I'm for ever swapping out cheap 2D fittings which have failed, and many have a sticker on the gear tray clearly stating not for continual use. Obviously missed by the installer.
As I've asked, does it say what that means?It clearly states not for continual use.
