The regs on cable supports are based on physical size, so the answer to your question is an unequivocal "yes".vinny8 said:Hello, 12 v cabling. In a false ceiling, does`it have to comply with Regs as per 230v. ie spacing of cable clips etc. replies much apreciated thanks.![]()
What do you mean by that? 1.0 or 1.5mm² twin & earth?vinny8 said:FWL........... Thanks i fully understand your info there thats very helpful. i am using 2 core 6amp lighting cable.
250mm is the maximum, but a smaller gap is good.Ban thanks as well . is a yes a yes or a yes. I take it the cables need clipping up at the same distances as others. 200mm i understand.
Why not?FWL_Engineer said:Twin and Earth cable should not be used for supplying 12V lights.
