Hi guys, well the unit was working fully up until the other day when my mother and my wife took him out on it and the battery's starting to die, they then carried it home ( I told them not to push it so it didn't damage the motors- whether they did and aren't telling me due to the cost of the bike is another thing 😂
My wife then put it on charge, it was left on charge for about 3 days (but would over charging cause an issue to battery's?) but when he then went to play on it , it wouldn't work..
Also whether or not the baby has tried to pull it out and ride it when the charger was plugged it and yanked the charger is another matter of debate and also a possibility..
I will test for voltage increase when on charge when I get home later.. It's also of note that coming off the battery is a little box which I presume is an overload or fuse? Connecting between the red line supply off the pcb and the battery itself.. (But I did bypass this to see if it worked with a direct supply and it made no difference)
Finally I'm also actually getting 13v off the battery not 12v (I considered it not important having 1v difference but art his stage Im just trying to give as much information as I possibly can
